![]() Join Date: Nov 2000
I'm curious as to experiences with rear sway bars. Is it worth it? I know on these trucks the front is the main concern though.
Thanks.... |
I have one on my 69 from Classic Perf. products. It works great.My truck didn't have any on it when I got it and I added the front and it made a world of difference. I don't know how anybody can drive without one. Then I added the rear one and it just stays flat on a hard turn.
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
I'm thinking about putting one on my 72. From what I've heard here, I think its a good idea.
------------------ 72 GMC C1500 2WD LWB As for me and my house, we shall serve the Lord.
72 GMC C1500 2WD LWB White City, OR As for me and my house, we shall serve the Lord. Looking for Oregon 72 GMC donor w/PS & column-shift auto |
Thats the Hillbilly way
My experience with rear antisway bars ,is all positive you will definetly notice improvement in handling and cornering .The ride may stiffen up a little , if i can remember the further from the pumpkin you mount the U bolts the stiffer the ride moving then closer to the center softens the ride a bit.
You will also notice less tuck and roll on acceleration and braking. I've always used Hellwig but wasn't happy with there quality control on the last bar I installed for a Toyota Tundra . I would try Classic Perf ,Mixup recommended. Bill ------------------ 72 3/4ton Custom Camper BB,400 Dynamax Cermax headers , air,ps,pb,leafsprings tilt,3.54 . 82 chevy silverado sb ,ps,pb pw,pd,air 350/350 Flowmaster 40. Torrance Calif. " If I knew I was going to live this long I would have taken better care of myself " [This message has been edited by Bill72BB (edited May 16, 2002).]
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
I currently don't have any on my truck now, and was looking at them on Classic Performance. I'm thinking it might be a good idea to install both front and rear. Is the rear bar harder to mount than the front??? Thanks again guys.
If it was me I would install the front one first ,you can get one at a junk yard just get new bushings ,stock one's cost about 10. Poly one will be more.
Easy to install. The rear will take a little longer ,you will have to mount everything loose and then line it up and start torking things. Bill ------------------ 72 3/4ton Custom Camper BB,400 Dynamax Cermax headers , air,ps,pb,leafsprings tilt,3.54 . 82 chevy silverado sb ,ps,pb pw,pd,air 350/350 Flowmaster 40. Torrance Calif. " If I knew I was going to live this long I would have taken better care of myself "
67-72 Addict!
I think I saw a post on here not long ago about the rear stabilizers and a few people were complaining that they were having problems installing them. One board member said the directions were not very accurate and you had to redrill some of the holes to get things lined up. I personally think it's a great idea. I hope some more board members can shed some light on this. I would love to have one on the rear to compliment the one on the front.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
my experience...the rear bar I purchased from Brothers about 2 years ago has been a real headache. They don't make their own but rather sell someone else's bar. The first thing I had a problem with was the bracket that holds the bar to the trailing arms. The bar intersect the arms at an angle but the brackets aren't long enough to span the joint in the arms so that you can drill the holes for attaching it to the arms. The other problem is with the end link bolts. The ones supplied are 11 inches long and when they are mounted on a truck that is lowered 4 inches in the rear there is only about 2 1/2 inches of ground clearance. When I checked out the ADDCO web site I found that their end links are approx. 8 inches for our trucks. I'm now trying to find a dealer or way to get answers from ADDCO so that I can get my bar mounted.
------------------ 72 swb cheyenne super 350/350 69 cst20 BB longhorn
72 swb cheyenne super 350/350 69 cst20 BB longhorn Warren, OR |
Led Sled! Discs R 4 ME!
![]() Join Date: Jan 2001
One note:
Before you install a rear sway bar you will need a heavier than stock front bar. Otherwise the truck will push. Its much easier to handle a loose condition than a tight one ![]() |
I had an Addco rear bar, but I didn't like the way it said to mount it so I never did put it on. I came across a bar off a 89 Camaro, after about a week of twisting and turning, i finally figured a way to put it on the truck and it looks like something the factory would have put on it. I made a webpage on how I put it on my truck, but webshots.com won't let you link pictures anymore so I have to redo that page, along with the rest of my site, but I will repost it once I get it fixed.
Thanks ------------------ '69 CST Short fleetside Lowered, 400 small block, 700R4, 3" dual exhaust, 40 series Flowmasters, 4 wheel disc brakes, all stainless hard and flex lines, front & rear sway bars, Dana 9 1/4" rear end 4.11's w/Detroit Locker, soon to have 18" rims Not my daily driver. More like my weekend A$$ KICKER. See my truck at: http://www.geocities.com/low69cst/ Future Automotive Engineer attending the University of Kentucky. Feel free to message me on AOL, SN- SS95ZQ8 My Dad's projects: 72 Short Fleet 4x4 Chyenne Super 72 Long Fleet 4x4 Chyenne Super Both 350 autos restored original
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
I'm just going to wait on the rear one, and maybe try and do a camaro one or something. After that one-piece glass, I don't need anymore headaches!! The front is where all the weight is anyway.
Low69CST, forward me the pictures and web pages and I will put them on my server. topherc@mindspring.com
------------------ Check out other members trucks 1968 50th Anniversary C-10 Suburban (Tows all these cars all over the place) 1968 50th Anniversary C-20 Pickup CST, Sold to Fine69 1969 SS Camaro Conv't 1960 Lakewood Travel Trailer 1963 Ford Falcon Wagon, Still For Sale Phoenix, AZ. Click Here for Parts and Venicles I have Available THINGS I AM LOOKING FOR: 67-68 SUBURBAN TRIM. $$$$ Reward for finding the 3rd door trim piece and the small piece that goes on the 1/4 panel right behind the 3rd door.Click Here to see the two pieces I need.
Just sitting here contemplating contemplation. |
Here, try this for now, until i get my pages made:
http://www.low69cst.freeservers.com/...%20Sway%20Bar/ ------------------ '69 CST Short fleetside Lowered, 400 small block, 700R4, 3" dual exhaust, 40 series Flowmasters, 4 wheel disc brakes, all stainless hard and flex lines, front & rear sway bars, Dana 9 1/4" rear end 4.11's w/Detroit Locker, soon to have 18" rims Not my daily driver. More like my weekend A$$ KICKER. See my truck at: http://www.geocities.com/low69cst/ Future Automotive Engineer attending the University of Kentucky. Feel free to message me on AOL, SN- SS95ZQ8 My Dad's projects: 72 Short Fleet 4x4 Chyenne Super 72 Long Fleet 4x4 Chyenne Super Both 350 autos restored original
![]() Join Date: Jul 2000
Your steering response will be much better, and the truck will corner flatter, with zero reduction in ride comfort. A properly installed stabilizer bar will not affect your straight line ride quality. I got mine from Brothers when they had a killer sale -- $89 + $22 shipping. The box said Hellwig, but there was an Addco part number on it. (Maybe Brothers buys from Hellwig who buys from Addco.) Anyway, the end links were too short, even for my 3" rear drop, so I bought some 11" links directly from Addco. The bar instructions suck, but you can figure it out. Just remember to mount the bar as close to the axle as possible and keep it parallel to the ground for max roll resistance. You can do this by jacking up the truck using the rear diff as the jack point. By the way, I have a coil spring rear suspension.
------------------ MikeB 69 C-10 Fleetside, mild 383, Dart Iron Eagle heads, Crane Energizer 266 cam and 1.6 roller rockers, Edelbrock Performer manifold and 600cfm carb, HEI w/ MSD components, 1986 front spindles/disc brakes, Vintage Air in-dash.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#15 |
I used a hellwig on the back of mine. It was one that clamps on. It worked allright until one of the clamps fell off when I was driving. I must of had the stereo cranked up, cause I didn't hear it fall off. I wouldn't recomend that brand, but would definately recomend getting a sway bar. It helps a lot.
LOW68 ------------------ http://www.geocities.com/a68rod
Build Thread |
#16 |
I have the clamp on from hellwig,easy install, has never fallen off,but I torqued the h#ll out of it. I put both front and rear on at same time,hahd to do over I might have done front first,but I am happy with it
------------------ 1968 SWB Stepside, pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,3 bolt seatbelts, original i6 and wood bed, seat from an 89 Chevy, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,WORK IN PROGRESS,Daily driver, 20 MPG, Freeland MI
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!! |
#17 |
My dad's 68
on my truck and my dads my dad rode the truck w/ out one once and it was weaving back anf fourth (i dont know if it would matter if his is tubbed or not) if any of you need um i have 2 on the part trucks jack
------------------ Jack M. 14 67 C-10 SWB 355 built T-350 tranny hurst shifter 15x8 &15x10in corvette rallys slammed**hopefully bagged this summer** 88 1/2 ton suburban 4x4 350/700R-4*having a 9 in lift w/ 38 in tires 69 SWB-parts 71 LWB-parts 72- LWB-parts grand dads truck 68 C-10 stepside fuel inj. 350/700R-4*soon in audi silver*
Jack M. 67 C-10 SWB 355 built T-350 tranny hurst shifter 17x8in KMC's on michelins, clear tails and back up lights slammed**UPDATE i have decided on my bag setup and will post further info when i recieve all the parts ****************************** 88 1/2 ton suburban 4x4 350/700R-4*having a 9 in lift w/ 38 in tires 4 12 inch Lightning Audios ****************************** 87 silverado 3/4ton jacked up 10-12 inches black and rubberized bed coating 35 in michelans ****************************** Dad's truck 68 C-10 stepside, 468 BB, tubbed, weld wheels, Nason black,lots more ****************************** grand dads truck 68 C-10 stepside fuel inj. 350/700R-4*soon in audi silver* ****************************** 84 toyota pickup 22R 5 speed 2WD slammed, shaved and all the body lines filled w/ buickGN scoop,bout to be sprayed in 2003 mustang green metallic w/ silver flames ****************************** S/N=BIGGYTYME@aol.com (hydros) "No fat chics, truck will scrape" |
