12-20-2007, 09:27 AM | #1 |
Freeeeee Mason...
Lets see those stereos...
I was wanting to see pictures/videos of everyone's stereo. I believe I probably have the loudest and most expensive one on the board. Let's see them guys.
^Pioneer Prem. DEH-880 ^Diamond Audio D661i Coax ^Diamond Audio D661i Coax ^Kx2500.1 Hidden under the sub box. ^Kx250.2 Hidden behind the passenger seat. ^Digital Designs DD9512 ^Digital Designs DD9512 Here's a video. YouTubes crap quality takes out most of the flexing you can see normally. Metal doesn't flex like plastic. I'm hitting in the high 140's with this single sub setup. I need to build another box though with lower tuning because this one bottoms on on EXTREME low notes. Sometime this week I'll get a picture under the hood of the second battery (Batcap 2000). Last edited by Pl4yboy; 12-20-2007 at 09:31 AM. |
12-20-2007, 09:40 AM | #2 |
Re: Lets see those stereos...
nicee system
heres mine..no speakers yet but i will probally but some in the door and maybe one under the seat |
12-20-2007, 09:48 AM | #3 |
Freeeeee Mason...
Looks kinda similar to my dash
12-20-2007, 10:04 AM | #4 |
Holy crap......you ever get hit in the drivers door and that think comes loose....you're a dead man!
That's a big woofer and who needs a spare change tray....you could probably stick $400 worth of quarters to that magnet! How often do you have to retighten all the fasteners holding your truck together?
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
12-20-2007, 10:04 AM | #5 |
Location: Sunny, Florida, some might call it South Alabama
Do the speakers in the door get wet or messed up due to the weather?
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
12-20-2007, 11:46 AM | #6 |
70+ ( Old Skool Club )
ttt
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
12-20-2007, 01:02 PM | #7 | |
Freeeeee Mason...
And I've only had two screws come out or loosen. One, the rear view mirror, causing it to fall down, and the other, the passenger side mirror. It fell off going down the road lol. |
12-20-2007, 01:07 PM | #8 |
[QUOTE=Pl4yboy;2493600]I know that a company makes some rubber covers that can be screwed in above them, and I was going to buy some but couldn't ever find them again./QUOTE]
Crutchfield sells them.
72 C10 lwb fleetside -stock 350/350 combo |
12-20-2007, 03:55 PM | #9 |
look at that sub, besides losing my hearing, I'd lose all my fillings to the magnet as well
1972 GMC Sierra 1972 GMC Super Custom Suburban |
12-20-2007, 04:50 PM | #10 |
Old member
Here is my setup. 25 w each speaker and it's more than enough for me...my daughter & son would argue with me on that but it's my truck!
Head unit: Tweeter's: Sub's: 3 way's under the seat:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 12-22-2007 at 05:51 PM. |
12-20-2007, 07:32 PM | #11 |
that last pic shows where 5X7's go in the cab corners, and i have a box behind the seat that holds a 12", amp under the seat
12-21-2007, 01:56 AM | #12 |
Old member
matthufham,
Do you have any more pictures of what you did to make the speaker inclosure in the corner of your cab. I like the idea just haven't seen a good way of doing it yet. Are you going to have some kind of box are just using the cab wall for the backside?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
12-21-2007, 02:51 AM | #13 |
Less than $100 WITH SPEAKERS at JC Whitney. Sounds as good to me as any and all of the above set-ups. The speakers are mounted in the dash next to each other in a factory mono speaker holder. And no damage to the dash.
Pl4yboy: By "hitting the high 140s" I'm assuming you mean you listen to that set-up while it is cranking out 140 dB of sound. Note that sound begins to damage your hearing when it is above 85 dB. Though the pain may be temporary, the damage isn't. Think about the future. My father-in-law who spent his 70+ years behind a running tractor engine with no hearing protection can't hear a word my daughter - his granddaughter - is saying.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
12-21-2007, 10:48 AM | #14 |
>130dB Moderator
Loud isn't everything... While volume gets you noticed, Quality gets you appreciated.
My old system has been posted several times before and has been the subject of a thread or two... Pioneer DEH-880PRS MB Quart 5.25" and 6.5" components Pioneer shallow mount 10's and ARC Audio FD4100 amp (under bow tie) Everything has been ripped out from the truck though and a new complete ARC Audio system is being put in. (4) ARC 10D2 subs (3) ARC6000 components (1) KS300.4 amp (1) KS1000.1 amp (1) PEQ preamp EQ
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
12-21-2007, 12:46 PM | #15 | ||
Freeeeee Mason...
12-21-2007, 01:40 PM | #16 | |
>130dB Moderator
Going with coaxials instead of components because you don't want to make more cuts seems strange because you have to have cut the doors to mount those speakers anyway...
12-21-2007, 06:42 PM | #17 |
i like the components you got, id like to have a huge sub like that, but ive already had one stereo ripped off and that screams break my window and steal me.
12-21-2007, 06:49 PM | #18 |
im sure theres a pic already on here, just have the receiver and components in, havent driven truck in months to put amps and stuff in
12-21-2007, 08:56 PM | #19 | |
Freeeeee Mason...
12-21-2007, 09:18 PM | #20 |
i welded the cab corners shut and cut a hole, 5X7 is as big as it gets, no room for 6X9s
12-22-2007, 01:48 AM | #21 |
Old member
Thanks for sharing that. I thought you did. I have herd there is some material you can heat and make it confirm to the wall of the cab without welding has anyone herd of it.
12-22-2007, 03:27 AM | #22 |
Live fast, die young
12-22-2007, 04:17 AM | #23 |
That's a good idea Matt...how does that sound?
12-22-2007, 03:45 PM | #24 |
its custom but also permanent. cut out the ashytray opening to the gas switch made a frame around stereo out if 1/2 balsa strips then fiberglassed it. relocated switch to where radio used to be.
12-27-2007, 07:24 PM | #25 |
