Old 12-23-2007, 04:54 PM   #1
bill8333
Alternator help
Hi y'all. I have a 1972 1/2 4x4 pick up. The PO I think converted the alternator over to a internal regulator. The reason why I say think is that the regulator on the radiator support is still hooked up to the regulator. My amp gage in the truck doesn't work but the truck is charging the battery and the truck runs fine. Any information would be welcome.
Have a Happy Holiday season
Bill Becky & Roxie
1972 K-10 L/B 4x4 Matching #'s 350 4 speed from the factory. P/S P/B
1981 GMC 1/2 L/B 4x4 one owner truck. 4" lift
2004 Dodge Cummins Diesel 4x4 Q/C S/B
1986 Dodge D150 L/B 2WD
bill8333 is offline   Reply With Quote
Old 12-23-2007, 05:52 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Alternator help
The amp gage does not work on a lot of 67-72 Chevy/GMC pickups or at least does not move a lot.
The trouble usually is because one or both of the short fuses located on the back side of the radiator support are blown.
I have found the best thing to do is to install a volt-meter either in or below the dash.
Danny - Southeast Missouri
Shyguy is offline   Reply With Quote
Old 12-23-2007, 06:25 PM   #3
bill8333
Re: Alternator help
Well I found one of the small fuses and replace it. My gage sits over on the left side like its not charging. I have seen a few like you mentioned but those are stitting in the middle of the gage.
Old 12-24-2007, 02:18 AM   #4
truckdude239
truckdude239's Avatar
Re: Alternator help
http://67-72chevytrucks.com/vboard/s...d.php?t=119379 read this post and make sure he converted it right. i did mine this way but i have a charge light and it works
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 12-24-2007, 04:05 AM   #5
Andy4639
Old member
Andy4639's Avatar
Re: Alternator help
I did the swap out too, the old amp meter never really showed me anything so I added the volt meter also. I tells the real story. Just follow the above instructions and it will be fine. Add a volt meter also.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-24-2007, 04:27 AM   #6
Wrenchbender Ret
Re: Alternator help
There are 2 fuses in rubber holders in the harness under the hood. If you replace these fuses it usually fixes the gauge. Sometimes they are corroded & need new holders.
Wrenchbender Ret is offline   Reply With Quote
