Old 12-23-2007, 02:37 PM   #1
sameyrasmea72
sameyrasmea72's Avatar
Well, I just picked up my Christmas gift to my self.....
A you can probably tell from the following write up, I do not know much about engines other than I like them to run. Anyway, I am trying to do a very correct restoration and I was dead set on using the original 402, but my mechanic (Brian Teal) finally talked me into letting him do a 454( I will just hold on to the original block).
So when someone pops the hood it will look like a stock BB down to the firewall markings and frame markings ect. The only major noticeable difference ( I hope ) will be the GM cast high-rise Holly intake and carburetor. The good stuff will be on inside. The block was bored .60 over so I guess it will be a 468ci. It has closed chambered heads, forged flat top pistons, L-88 valves, cam, ect. Like I said, I don’t know much about engines or how many Ponies it will put out, but I know it will run like a scalded ape and still look stock enough to keep me happy .
My biggest concern is that the stock air breather will fit on a Holly carb. I don’t have the carb yet, so I cant test it for sure yet but was assured that it would. DOES ANYBODY KNOW FOR SURE IF IT WILL FIT?
Anyway, I cant wait to get it mounted on the frame along with the transmission and drive shaft. Then I won’t like too much to have the rolling chassis finished …………….…Jason
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 12-23-2007, 03:18 PM   #2
killer71
killer71's Avatar
Re: Well, I just picked up my Christmas gift to my self.....
i was hoping you were gonna say you were actually looking for a 454...cuz i have one just built with 14,000 miles by a guy that actually worked for nascar...oh well...hope everything works out for ya...sounds like a hot dog!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 12-24-2007, 12:59 AM   #3
Hart_Rod
Hart_Rod's Avatar
Got pics? That might look pretty cool in the 52.........
Hart_Rod is offline   Reply With Quote
Old 12-24-2007, 09:04 AM   #4
breeh
Recovering 67-72 Addict
breeh's Avatar
…………….…Jason
Should not be any problem if you use the factory spacer.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 12-24-2007, 09:53 AM   #5
mnunn454
mnunn454's Avatar
Am no expert on factory air cleaners, but I am definitely a proponent of 454's in Chevy pickups.
I just replaced a non-original 66 396 in my 69 short fleet with a 454. It's got a Comp Magnum cam, TRW slugs, Edelbrock Heads and Intake and a Holley Carb. Should be in the 450HP+ arena and 500+lf ft of torque. I love the combo. Plenty of grunt for that "push you back into your seat" feeling I enjoy so much.
Hope'e you're just as happy with your decision to upgrade to the 468.
Keeping the original engine around for a numbers matching swap-out, should you ever decide to go that way, is a good thing as well.
Congrats.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
