Old 12-27-2007, 04:00 AM   #1
shortbed70
shortbed70's Avatar
72 upper arms and spindle fit?
Will the upper a arm and spindle from a 72 1/2 ton fit my 65 lower control arm? I have a drop pocket lower and don't want to lose it while doing a swap to disc.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 12-27-2007, 05:36 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 72 upper arms and spindle fit?
Lower ball joint is different. You need to swap it for a '72 balljoint,... if that's possible with the aftermarket lower control arm. Also the outer tierods will be different. Search this section for "disc brake swaps". It's easier to swap all the '72 stuff (steering linkage included.) If you have to buy new,... it's CHEAPER to use '73-'87 stuff.
Keith
Convert to disc brakes.
