Putting in a vortec
I have a 70 blazer and putting in a 98 350 Vortec with the fuel injec. system.
Has anyone have any tricks or info about the wiring and cpu. Im putting a 700r4 behind it whats the best way to hook-up the the lock-up to the CPu on the motor or is it better not to put them together. Thanks for the info. |
Oh..never mind....
Re: Putting in a vortec
I am doing the same conversion myself, so I'll share what I know. You have a couple of options. I have heard of some people getting a factory service manual and cutting their own harness. Another option is to send your harness and have them cut it for you. A place called Fuel Injection Specialties does this kind of work for about $450 if I recall right. The other option is to have a place a like Howell-EFI build you one from scratch for about $500. One thing to consider is what your local laws require for what emissions equipment that you will need to retain as part of the conversion. This will determine what programs need to be deleted from the cpu when it is reprogrammed as well as what parts of the harness need to be left on. Both places can do the cpu work for $250 to $350 depending on what you need. As far as the transmission is concerned, my understanding is that the cpu is only able to run the 4L60-E that was stock with those engines. You may also wish to contact a place called BTB Products, since they do these conversions as well, but their price tag is a little more then the others that I listed. Each place has a website and were very good about answering questions when I called them. If there are other things I can answer, feel free to ask. I'll help if I can.
1972 Blazer -6 inch lift -35 inch BFG A/T's Turbo 350 NP-205 454 BB (for now) MORE TO COME !!!!!! Now going to 2WD!!!!! Sold. ![]() ![]() ![]() I got it back after 22 years and did not even know it !!! THE STORY HERE Project Low Down Dirty Rat |
i am doing the same set up from a 98 vortec in a 70 blazer. what i have found on the Tran 460le if it came from a 2wheel drive u need to get a tail shaft that advance adapters sells with a 205 conversion for the transfer case. summit has the same tailshaft as advance adapters for less money!! as for the wire harness i haven't decide whether or not to try to rewire or spend the money for someone else to But for sure u need to have the computer re-flashed. hope that helped
what do you mean re-flashed what does that do for the computer?
PROJECT 7DEUCE
![]() Join Date: Dec 2002
You may also want to look into street and performance they have some pretty good info.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Oh..never mind....
Re-flash is just another way of saying to reprogram.
When I first started looking into doing this conversion, I called Street and Performance. My understanding is that most of their computer and harness work is farmed out to places like I mentioned do it for them and they mark it up.
can u find a wiring harness diagram on the internet? for that motor 98 vortec?
Another thing,the 700R4 is longer than the stock tranny so if you have a 4wd you will need to locate the motor farther forward or move the t-case back resulting in needing new driveshafts or having the old ones lengthened/shortened.I'll just keep my good ol' carb'd small block chevy has used for decades and not have to do these mods,but that's just me.
![]() Last edited by 1969k10stepside; 12-30-2007 at 05:57 PM. |
its go to be a 2wd now. thanks for all the info.
cant u buy form AA the motor mounts and move the motor forward and leave the drive shafts alone. Use electric fans?
