12-27-2007, 02:18 PM | #1 |
cab mounts
I bought a 1972 k-10 4x4 and while striping down I found out it had a 69 2wd cab on it. Well i pulled the cab off the front 2 cab mounts on the body have been cut out for some reason. Is this have to be done to mount a 2wd cab on a 4x4 frame or does the have to be done at all? will add pics if i need to later
12-27-2007, 02:38 PM | #2 |
Luv the Crewcabs
Re: cab mounts
Welcome from Indiana
Not Sure i Follow what you are Saying, Where is it cut at? Only thing that Come's to Mind is with 2x4 Cab you won't have the clearance needed for the Tranny & Transfer Case, Is that the Area that it was cut at?? Probably gonna have to Post a Pic to Get the Right Answer............. Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
12-27-2007, 02:49 PM | #3 |
Re: cab mounts
no the actual mount on the frame is cut out alittle will post pic later kinda doing the christmas with the family right now
12-28-2007, 03:05 AM | #4 |
Re: cab mounts
There's no reason to cut the front mounts. The rear mounts are in different locations for 2X 1/2T vs 4X or 3/4T
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
12-28-2007, 05:16 AM | #5 |
Re: cab mounts
Does anyone have a drawing of the differences? With what to do to correct the mounts to fit the 4WD frame mounts?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
12-28-2007, 06:44 PM | #6 |
www.infantimachine.com
Re: cab mounts
The cab mounts on the cab should all be the same for 1/2 ton and 3/4 ton.
The rear mounts on the frame are at different heights,they use taller rubber mounts on 3/4 tons. |
12-28-2007, 09:07 PM | #7 |
Re: cab mounts
figured it out it happends to be a 73 up frame
