madcow
Strange Oil Leak???
I have a oil leak from the second bolt on the right front side of my intake manifold. Its a Edelbrock.
There is no leak when the truck is running and no leak when I shut it off on short drives. There is a small, about a tablespoon full drop of oil in the indent where the bolt screws in the next morning when I go out to look. Could the manifold be cracked? I'm thinking about trying the non-hardening thread sealer. Any suggestions appreciated.
_____________________________________________ 1970 SWB 4x4 350 4 speed Factory AC |
Grease Monkey
Re: Strange Oil Leak???
Do you know if the bolts were sealed when it was installed? What you might want to try is take the bolt out and put ultra black sealer on the threads and that should fix your problem.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
thats a normal leak when intake bolts are installed without thread sealer
I had the same problem with my Edelbrock manifold. I cured the problem with "Permatex" High Temp Thread Sealant.
esll. ![]()
Tomorrow is for doing today's stuff. ![]() ************************************* This truck has just the right amount of energy for me! ![]() Author: Warren Lake .... (member) Last edited by EAST SIDE LOW LIFE; 12-26-2007 at 08:27 AM. |
Zappaphile!
clean it out really well before you seal up those threads =)
1969 C20 LWB Camper Special - The Beater.. 1998 Cheyenne V6 - 4/6 Drop - For The Son |
72 C10 lwb fleetside -stock 350/350 combo |
madcow
Gracias to all the input.
madcow
I must be doing something wrong or cracking up
![]() When I took the bolt out to clean it the oil seeped out of the manifold gasket around the bolt hole and the one next to it (towards the front of the engine). What's throwing me off is that its leaking at the front highest point with the engine off while the engine slants to the rear of the truck. Could there be too much oil pressure? Maybe the bolts too long and is bottoming out in the well? Its a standard oil presure pump. Anyway I used the high temp thread sealer and will wait until tomorrow to fire it up. Next I think I will replace the intake gaskets if this doesn't work. What a way to spend Christmas vacation.
