Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 12-24-2007, 05:47 PM   #576
Frizzle Fry
Frizzle Fry's Avatar
Re: Joined the Short Wheelbase Club *69 Tahoe Project*
Drivers side is 98% done. Still waiting on the correct bracket and another ebrake cable for the pass-side. BTW both cables are the same P/N even though NAPA calls out a driver and passenger side... The P/N I used is 94724 for both.
ebrake cable routing; the length is perfect for this configuration:
I'll add another clamp further forward on the trailing arm:
I need to get some new retainer clips, but I think the OE style will work perfectly here:
Frizzle Fry is offline   Reply With Quote
Old 12-25-2007, 03:55 AM   #577
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looking damn good I see your getting the rain too... How much block do you have in the rear..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-25-2007, 05:51 AM   #578
desertrat
desertrat's Avatar
This picture looks cool. I so much want to dislike big wheels but you guys sure make them look good.
Coming along nicely Frizzle!
desertrat is offline   Reply With Quote
Old 12-25-2007, 05:55 AM   #579
babyblueoval
babyblueoval's Avatar
Frizzle,
I just realized that's the same tire I'm running, different size though (275/45x20).
Have you been able to put many miles on them yet? Just curious what you think.
They were recommended by Jim at the TireRack so I figured they'd be good.
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
Old 12-25-2007, 11:18 AM   #580
Frizzle Fry
Originally Posted by babyblueoval View Post
Frizzle,
Not many miles on them yet but so far so good. Low road noise. There are pretty well rated in all the reviews.
Old 12-25-2007, 06:57 PM   #581
gringoloco
A guy with a truck
gringoloco's Avatar
Frizzle,
Yoko Parada Spec-X on my Blazer. Nothing but good for me...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-26-2007, 05:19 AM   #582
b&a72
Active Member
b&a72's Avatar
I am also running the Parada Spec X great tires. I have nothing but good things to say about Yoko's I run them on my 4 banger, and my Tahoe as well.
b&a72 is offline   Reply With Quote
Old 12-26-2007, 05:55 AM   #583
Rokcrln
Rokcrln's Avatar
Looking good! Heck with as small as those brakes look I bet you will be able to change pads with out removing the rim
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 12-26-2007, 07:49 AM   #584
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Lol. Looks good, I LOVE big wheels
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 12-26-2007, 01:23 PM   #585
babyblueoval
Sounds like good recommendations to me.
I CAN'T WAIT TO GET MY TRUCK TOGETHER!!!!
Jim
Old 12-26-2007, 04:16 PM   #586
Hart_Rod
Hart_Rod's Avatar
FF, maybe I missed it, but how are you connecting the caliper to the brake lines? Is it a rubber line or a hard line? Thanks,
R/
Hart_Rod is offline   Reply With Quote
Old 12-26-2007, 05:46 PM   #587
Frizzle Fry
Just rerouted the OE hardline and used the thread adapters supplied in glock's bracket kit:
Old 12-26-2007, 06:50 PM   #588
Hart_Rod
Hart_Rod's Avatar
Thanks, I was just making sure. All my other cars that had rear discs used a rubber line to go from the caliper to the axle. Since it uses a hard line, I'm assuming that part of the caliper doesn't move.
R/
Old 12-26-2007, 08:31 PM   #589
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
From that picture, that part of the caliper does move. I'd recommend getting some rubber or braided hose in there. It's a very small movement and might be ok, but you'd hate to work harden the steel and get a crack...
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 12-26-2007, 10:03 PM   #590
Frizzle Fry
Good call guys.
Old 12-28-2007, 07:24 AM   #591
gringoloco
A guy with a truck
gringoloco's Avatar
W3rd. That's a floater...
-Chris
Old 12-28-2007, 06:17 PM   #592
low burb
I've been trying to get the pics on page 1 and 2 for days now and all I get are red xs. Is any one else having the same problem? I can see the recent ones just not the earlier shots. Any one have a suggestion on how I can remedey this? Thanks, Michael
Michael
1971 GMC Suburban "Crusty"
2000 GMC Sierra 1500 2wd
1978 Scout II
1992 Passat Syncro
low burb is offline   Reply With Quote
Old 12-28-2007, 06:24 PM   #593
babyblueoval
Michael,
I'm good but there are about 50 pics on the first page alone.
Maybe your browser is timing out? Maybe a Ctrl/F5 will help or clear your temp files and try again.
Dunno. Might be worth a try.
Jim
Old 12-28-2007, 07:09 PM   #594
Frizzle Fry
Here's the link to the photobucket account for the Burb. See subfolders on the left: http://s6.photobucket.com/albums/y23...69%20Suburban/
Old 12-29-2007, 05:39 PM   #595
babyblueoval
Let's see, are you the one with the orange sweat shirt and matching hair?
I pictured you looking a bit older than that.
Jim
Old 12-29-2007, 07:20 PM   #596
low burb
Thanks for the link, Mike. I can see clearly, now.....
Michael
1978 Scout II
1992 Passat Syncro
Old 12-29-2007, 08:02 PM   #597
67_C-30
I have a radical idea!
67_C-30's Avatar
The name Frizzle Fry puts him at around 30-ish if I had to guess!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 12-29-2007, 08:04 PM   #598
67_C-30
67_C-30's Avatar
BAM! I just checked the profile, and I was right! I'm guessing you were jamming to Primus in high school too!
My trucks
Old 12-30-2007, 09:30 AM   #599
Frizzle Fry
Actually that is a cloned version of me. I duplicated myself for those jobs where you need an extra hand. You know the saying; if you want something done right...
yes sir! yes sir! I don't like your per-son-ality...
Old 12-30-2007, 10:26 AM   #600
Hart_Rod
Hart_Rod's Avatar
FF, just wondering what you figured out for the rear brake hoses?
R
