Engine Swap Manual to Auto ???
I am swapping out my engine and tranny from a 350/4spd granny to 350/700r4. I have a two piece driveshaft and would like to know how much needs to be cut or is there something else I can use in place of this drive shaft. Please just point me in the right direction. I have read the 700r4 installs but nobody comes right out and says what they did during their swap...
All Toys: 1971 C10 Fleetside - I needed it! 1970 C10 Stepside - Midlife Crisis 1969 C20 3/4 Longbed - Beast! 1966 Mustang Fastback - Daily Fun 1965 Mustang Fastback - Money pit! |
Re: Engine Swap Manual to Auto ???
Well, the 700r4 is 3 inches longer than a 350 turbo short shaft. So, I'm thinking 3 inch cut off the front drive shaft. Although, you might want to measure both trannys to make sure. Or, wait and measure the length you need after you install the 700. I'm going to be doing the same swap in the Spring. Now, I have a one piece drive shaft that came off a 84 burb that I hope I can use. It is 1" shorter than needed with the 700r4. I won't be sure of the fit until I get it installed.
1997 GMC Sierra Ext 1965 Mustang Last edited by 70GMCer; 12-31-2007 at 07:39 AM. |
