Pulled My Engine & Trans ??? Value
I pulled my 350 and the granny 4spd today at the hobby shop on base. Everything went fine.
I am switching to automatic 700r4 tranny and I notice the 4 speed tranny mount needs to be remove but it is not held in by bolts. How did you guys remove this bracket that the 4spd mounts to? Also how much is a granny 4spd worth?
All Toys: 1971 C10 Fleetside - I needed it! 1970 C10 Stepside - Midlife Crisis 1969 C20 3/4 Longbed - Beast! 1966 Mustang Fastback - Daily Fun 1965 Mustang Fastback - Money pit! |
Re: Pulled My Engine & Trans ??? Value
start grinding away.......or if you're good with a torch, burn the rivet heads off and use a punch to knock out the remaining part of the rivet.
1997 GMC Sierra Ext 1965 Mustang |
Thanks!!! That is what I needed to know...
Granny 4 speeds are a dime a dozen because many people want to do exctly what you are doing with them (ditch them in favor of something more modern)
Maybe a C-note or two if someone really needs one
Are you retired too? Nonsense! I'm in my prime |
Chevy One
Hay 70C10Step, I take it you are a Vandy-Land, at least that is what we call it from up here at Hill AFB. I sometimes go TDY to there. Try to look you up next time I come down. Have a Great New Year!
Chevy One ![]() 67 1/2 Two-on-the-Floor 67 Nova 2Dr Sedan 03 Monte Carlo I'M NOT OLD, JUST A CLASSIC!!! |
Look me up I am on the global, Whittaker, Isaiah at Vandy Land... I am headed to the hobby shop!!!
Chevy One
Will do, I had better get out to the shop myself. Have to let the heaters warm a bit before I start to work. I know you are not having that issue down there. Its snowing here
![]() Join Date: Jan 2002
granny 4 speed brings bout 35-50 around here. it all depends who needs one at the time you're selling one.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
I will be over at Hill in a month or so for a meeting. It is a little windy here right now... I am swapping in a 350 and 700r4 while I decide whether to build a 454 stroker or a 350 stroker. Big block is going to win but I still have to ponder a little..
Chevy One
Isaiah, look me up when you get to Hill; Chad Peterson Bldg 1217, I am a ES for MM Trans & Handling Ground Sys. We can do lunch and BS if you find a minute or two . I am just starting on my 67 2WD LWB. Have 283 bored 60 to a 292 with new vortex heads. Converting to disk up front and a 3/4 drop. Hope to see you then
Cool, I will find you and we can do lunch.... I might even have some time to wrench!
Chevy One
Sounds good, see you then. Remember it will still be cold here. I am lucky to have a 30' by 48' shop with "some" heat.
