01-12-2003, 07:37 PM | #1 |
aka Crusher, Crushergmc
Brake caliper parts question.
OK, so it's been a while since I took my front end apart. What parts do I need to mount the calipers. I've got the bolts and the "O" rings. Is there a metal bushing and/or spacer?
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
01-12-2003, 08:44 PM | #2 |
Each bolt has a bushing that the caliper slides on as well. Usually a rebuilt caliper comes with the bushings installed. (piston side) Thier outer diamater is the same as the bolt head and the inner is a lillte bigger than the bolt shaft. I belive they are about an inch tall standing on end. Be sure to lube up the o-rings with silicone lube so the calipers can "float".
Zurbo's Chevy - 1972 Black/White Cheyenne Super. 402 Big Block /THD 400, factory air and tilt. My other Chevy - 1998 Camaro SS |
01-13-2003, 12:07 AM | #3 |
Thanks Zurbo!
