Can a 4WD frame be swapped over to 2WD?
I found a 4WD frame for my crew cab project, But I want a lowered 2WD. Can I swap a crossmember/suspension off a 2WD, or is the front of the frame rails different??
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Can a 4WD frame be swaped over to 2WD?
i read a thread recently where a guy wanted to convert a 2wd truck into a 4wd and they said it would involve drilling but it could happen so i would think that the reverse is also possible the original poster on that was Shamil and it was within the last week if you want to view the thread
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Yes, it can. From what I understand, both sets of holes should be there. Find a newer frame to take the suspension off of. My 91 parts Suburban the front suspension is bolted not riveted in.
"Your tax dollars at work" |
67-72 parts collector,…
![]() Join Date: Nov 2002
Check out Gringoloco's blazer project. It use to be a 4x4. Then converted to 2wd. Now getting a Porterbuilt "Dropmember". It's possible. You just need a donor 2wd truck for parts.
krazy hillbilly from Kentucky
If you weren't so far away, I'd swap you frames. I'm looking for a 4x4 frame for an 84 long bed. I have a 2wd long bed with 3.73 rear gears, new brakes, rotors, calipers, and lines up front and pretty good brakes out back.
1969 Chevy CST/10 "Old School lives and breathes in the heart of a chosen few ![]() 1984 Chevy C10 Silverado "Life, Liberty, and Ford's Pursuit of Chevy taillights" You say "Obsessed with my trucks" like it's a bad thing |
I'd just look for a 2wd frame.They should be easy to find The one ton frames are bigger (heavier duty).I'd look for a longbed 1/2 or 3/4 ton 2wd chassis and just lengthen it and use it..
bhunt31,you must not be looking hard enough. ![]() Last edited by 1969k10stepside; 01-02-2008 at 06:50 PM. |
#7 | |
Re: Can a 4WD frame be swapped over to 2WD?
There is not alot to choose from here! you southern guys probably use what we call "good condition" as parts trucks
haha, I dunno bout that, cuz I know I'll run anything that doesn't have parts falling off of it driving down the road...sometimes we'll even run that...so long as the parts aren't necessities, like, say, wheels and tires.
