07-13-2004, 04:41 PM | #1 |
Inner axle shaft lengths?
Does anyone know the length from center of u-joint to end of splines on inner shaft's of a 71 k10 dana 44 . I deserve some sort of award for my actions, I threw all of my old axles out when I bought a set off ebay, turns out the new ones were for for closed knuckle. I'm trying to order a set from moser but I need dimensions, or perhaps a part number. Go easy on me.
71 k10 swb 72 k5 72 Burb 4x4 72 GMC Burb 4x4 |
01-02-2008, 12:06 PM | #2 |
Re: Inner axle shaft lengths?
Did you ever find the axle shaft length. I'm also having problems with my D44.
01-02-2008, 01:27 PM | #3 |
rustyg, where are you located? I think that I still have some shafts lying around in the garage. I do know that my corp 10 was different length than my dana44 shafts. The diff is not in the same location... I'll PM you my number... I live in Lebanon, PA.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
01-03-2008, 05:17 PM | #4 |
Everything is work in progress
Get the number off your axle and go here and you can find exactly what inner axle you have.
http://www2.dana.com You gotta dig but it's all here
Good luck with your truck! How much?! It's just an old truck part!! 49 International on a 80 GMC 3/4ton 4x4 chassis 48 International KB-5 2 ton dump bed 04 Honda CRF "500" 09 Honda CRF450 fuel injected rocket 03 Suzuki hayabusa carbonfiber wheeled monster. 02 Ford diesel stretch van (toy hauler) 01 38' Monaco diesel pusher motorhome Last edited by cobinder; 01-03-2008 at 05:20 PM. |
01-03-2008, 08:16 PM | #5 | |
I need the dimensions for axle shafts 904686-1 and 904686-2 neither one has dimensions listed. I do not have the original shafts and the other GM D44 shafts are to long. |
01-04-2008, 07:14 AM | #6 |
Rusty, look on the bottom of page 76 (of the document) (82 of the pdf) and you'll see all the info your after
http://www2.dana.com/pdf/XGI.PDF
Good luck with your truck! How much?! It's just an old truck part!! 49 International on a 80 GMC 3/4ton 4x4 chassis 48 International KB-5 2 ton dump bed 04 Honda CRF "500" 09 Honda CRF450 fuel injected rocket 03 Suzuki hayabusa carbonfiber wheeled monster. 02 Ford diesel stretch van (toy hauler) 01 38' Monaco diesel pusher motorhome Last edited by cobinder; 01-04-2008 at 07:37 AM. |
01-04-2008, 03:53 PM | #7 |
Im back in AL now so I am of no help... good luck
01-04-2008, 04:54 PM | #8 |
The warn catalog has the lenghts. If you didnt already find them Ill check for you tomorrow when Im at work.
01-04-2008, 07:46 PM | #9 |
'71k204x4454
The ones I have out of a dana 44 are short 18.5" and long 36.25". Hope that helps. (That first post sure is old).
1971 K20 4x4 1964 buick skylark convertible |
