01-04-2008, 06:40 PM | #1 |
steering column
I am putting in a tilt steering column from a mid 80s blazer and was wondering what I can do to cover the key hole and shift opening on the column. I plan on using the stock key (in dash) and mounting the automatic shifter on the floor.
Thanks Mark |
01-04-2008, 06:45 PM | #2 |
its all about the +6 inches
Re: steering column
You'd be way ahead to sell that column, and get one out of a 72 - 81 chevy/GMC van. They are very close to being a direct swap, and very few could ever tell it was not a stock piece.
the one you have has the issues you mentioned, and also it is larget in diameter too if i remember right. |
01-05-2008, 02:48 AM | #3 |
Re: steering column
1997 GMC Sierra Ext 1965 Mustang |
01-05-2008, 04:35 PM | #4 |
TILT COLUMN GURU
Re: steering column
Check out this link for the correct tilt column you need.
http://67-72chevytrucks.com/vboard/s...teering+column |
