67-72 plow trucks
lets see them 67-72 plow trucks i have 5 4wds here [3 71 and 72s] and no plow truck so i got another 72 today to turn into a plow truck and winter work horse. when i first seen it i couldn't wait to get my grubbys on it for parts but after looking it over i think i'm gonna give it a set of rockers and a coat of industrial enamel and put it to work. 400 sb auto and posi no pics yet i haven't got it home yet
common sense isn't so common anymore |
Re: 67-72 plow trucks
Here is my 71 4x4. It works really well even though it has an engine driven hydraulic pump setup on it.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Roadtrip!
![]() Join Date: Feb 2003
Here are my 71 and 72...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
too much stuff,
With the snow you get, I can see why you have two trucks! Jim
My 69 4wd use to be a plow truck in it's previous life near lake Michigan in Wisconsin..It's no longer a plow truck,the plow wouldn't work good with the 6" lift anyway.Besides,the truck body couldn't handle anymore cold salty winters...
![]() Last edited by 1969k10stepside; 01-05-2008 at 05:32 PM. |
nice looking plow truck jim. isn't an engine driven pump better ,faster easier on your charging system and useful for many other accesorys like a sander, wheele lift or the jaws of life eric, good te see them earning their keep, i bet that blazer gets around very well witch would you rather plow with. i imagin the windows in the pickup are easier to keep clear
Roadtrip!
I haven't hardly used the blazer. The 71 longbox i have is a work in progress. Every year i upgrade something on it and keep plowing. I would think the short wheelbase would be better personally. Actually, the blazer would look good at your place...
Jims short step, That truck looks too good to be out plowing with.
i was thinking the same about jim's truck too. eric bring it down i think your right and i have plenty of room
Resident Curmudgeon
![]() Join Date: Dec 1999
Here is my K2500 GMC. Just completely rebuilt front and rear axles, brakes, suspension and replaced complete cab floor, rockers, supports, etc. As of today it has plates and is now inspected, registered and road worthy for the first time in probably 15 years. These pics were taken back in 2003, though she still looks about the same today.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Nice to see them pushing snow.I don`t have any old pictures with a plow mounted.
Looks good at 20-ft .....
Jeez Guys !!!!!! That looks awful.
Reminds me of the eight miserable Winters I spent in the Chicagoland suburbs. You ought to move to the South. When we get snow, it's usually gone the next afternoon, and seldom ever lasts any longer than 2 - 3 days. And NO SALT on the roads. |
that don't give you much time to have any fun! your snowmobile season is shorter than ours even on a bad year
What is there today that the plow mounts would fit our trucks ? Brother has a Fisher plow for the late 70/early 80's and one for the '88 on up trucks. Will plow mounts for 73-87 fit on 71-72 4WD's ??? Custom mod's needed ?
72 Chev C-10 90% restored (former AZ truck) ... 71 Chev K-20 Cheyenne my vacation crusier... 72 Chev C-10 Now retired and striped after many faithful miles... 72 GMC 1500 Retired to the junk yard after bought new in '71... |
i would thinkthat since front axels interchange frame widths must be the same so 73-87mounts should fit our trucks with little or no fab work
#15 |
I bought an`84 application for my trucks and everything bolts up except a hole on each side needed to be drilled.The`73-up body is straight across the front and 67/72s have a peek in the center,so the plow mount needs to be moved forward just a bit.One hole lines up on each side.I welded a tab for the mount to hit against since it was designed to hit on the spring mount.
