01-12-2003, 10:25 PM | #1 |
2 questions ????
If you look at this thread:
http://67-72chevytrucks.com/vboard/s...threadid=34854 you notice that the driver side valve cover has the pcv valve on it. on mine, it has the same setup- minus the pain in the ass tpi setup, but the pcv valve comes out of the passenger side valve cover. - is this right? do I have it on the wrong side??? q#2: when I turn off the key to my truck, it stays running ( not dieseling ) for about three seconds. if I flip my manual fan cutoff for my electrics, it shuts off immediately. the thing is, I have my manual fans wired into the fuse block. what the heck? will this hurt anything>? |
01-13-2003, 12:11 AM | #2 |
its all about the +6 inches
For #2, your fan is acting like a generater. It is spinning which turns to electrisity and backfeeds up the wires. Since nothing is keeping it spinning, it slows down untill there is not enough power to run the coil...and then your engine shuts off.
Try moving your power source...as in another spot on your fuse block. If that don't work, they sell a little leectronic gizmo that will stop this from hapening...think of it as a check vavle. I doubt it'll hurt anything though. |
01-13-2003, 12:31 AM | #3 |
#1--makes no differance
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
01-13-2003, 10:15 AM | #4 |
You could use a diode to stop the fan from sending electric current back to the fuse block. The only problem may be finding a diode that has that high of a current rating. Going to radioshack and reading the specs, you may find one.
01-13-2003, 01:14 PM | #5 |
English Chevy Owner
Something that draws as much current as an electric fan should be wired through a relay. At the moment you are putting a very large current through your fan switch which could lead to it overheating and burning out or even setting your truck on fire. The previous owner had wired the electric fan like this on my truck. I added a relay into the circuit when I realised the back of the switch was getting too hot to touch. My fan also windmills when it is switched off. It used to generate enough current to light the illuminated switch until I put the relay in.
It'll cost you a couple of dollars for a good quality relay, fit one and problem solved.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
01-13-2003, 04:36 PM | #6 |
oh, yeah, if you don't have a relay, you ought to get one. Good point Lippyp
