![]() Join Date: Dec 2002
Lower with Longer spring Shackles ?
...........Planning on lower rear only ( 1 1/2 to 2 inches) to attain a 'level' look.....Do they still market extra length spring shackles to accomplish this ?....My truck has leaf springs......... Appreciate any other ideas and comments on the over-length spring shackles....................Jim
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
Calibration Engineer
yeah, lots of companies make shackles, and they're extremely cheap too.. belltech, djm, western chassis (recommended), they're all pretty much the same.. most are 2" or 1-2" adjustable
you can also get springs dearced
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
or remove leaves...
![]() Join Date: Mar 2000
We stock Western Chassis drop shackles if interested in them you will find them on the following page of our web site
http://www.gmcpauls.com/lowering_springs_&_parts.htm With the Western Chassis drop shackle we stock you can lower the rear either 1" or 2" GMCPaul |
Progress = 0%
I made my own when I lowered my (then GMC) suspension. I lengthened the rear shackles and then raised the front mounting bracket on the frame. If you go too low, the leaf will hit one of the bed braces. I ended up putting a small notch in that brace. If you can weld and want to save a few bucks, it's pretty easy to do
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
