01-05-2008, 05:36 PM | #1 | |
FarmBoy.
Engine start up precautions after overheat?
alright,
so, as some of you know, my dad and truck had a bit of an accident involving a tree. after getting it out of the snowbank, we drove it home. but, the bottom outlet on the radiator had pulled out of the radiator itself. needless to say, the temp idiot light was the one calling me an idiot. we only drove it about a mile, parked it in the garage, and that was that. this weekend, the plan is to put another radiator in it, and start it up again. i was wondering if there was anything you would do as a precaution before starting it up? it's a 307, 2 bbl, and headers, if that makes a difference. i was thinking a thing of Slick 50, might help? or some other additive? just hoping for some insight. thanks in advance! -Sam.
1969 GMC C1500. long fleet. 307. 3 on the tree. 3.07 gears. Oliver green. Bent and bruised. Daily Driver. Quote:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993 |
01-05-2008, 06:09 PM | #2 |
Gone to greener pastures
Re: Engine start up precautions after overheat?
IMHO, just fire it & see what happens.
If there's any major damage, it's already done. Although you may have taken a few thousand miles off the engine. Them small blocks are tougher than most people think. |
01-05-2008, 07:14 PM | #3 |
its all about the +6 inches
if you only drove it a mile... then I highy doubt you did any damage.
On a side note, I would NEVER recomend putting slick 50 in your engine. Unless you LIKE having sludge in the oil pan at least. |
01-06-2008, 01:29 AM | #4 |
I would pull the dipstick and check for water in the oil in case the head gasket went. Other than that start it up nad see what happens.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
01-06-2008, 01:51 AM | #5 |
I have a radical idea!
X2
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
01-06-2008, 11:35 AM | #6 |
even more importan.... AFTER starting it. If the water is at the bottom of the pan, the dipstick won't reach it, but once the oil and water solution is made, it'll be real easy to spot on the dipstick.
Dark or gold oil... good Coffee with 3 creams in color... bad Last edited by Longhorn Man; 01-07-2008 at 09:02 PM. |
01-07-2008, 02:39 PM | #7 | |
FarmBoy.
alright, good news!
we fixed the radiator, and started it up tonight. after the initial moisture burnt out of the system, the smoke was clean. then we let it run for about 5 minutes, and checked the oil. it was that nice oil color, and not the three cream, two sugar coffee color Andy was talking about. so, just figured i'd put some closure on this thread. thanks again for the help guys. -Sam.
01-07-2008, 02:47 PM | #8 |
Glad it worked out for you.
