Old 01-09-2008, 03:02 AM   #3
James McClure
One shot, one kill.
Re: While ripping apart the dash..
Kix: Sounds like the flasher is bad like BLE said. All a flasher is, is an auto reset circut breaker set to open at an amperage just above what the lamps draw. If this "set point" drops or the draw increases the lamps will flash faster. Reverse is true if the set point goes up or you blow a bulb. Lamps will flash slower or not at all. Thats why when you hook up a trailer the signal lights & 4 ways will flash faster (greater amperage draw). I use a "signal stat" 522 in both the signal lights and 4 ways and they work well with or without a trailer. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
