More vacuum leak questions
Hey everybody...If you remember, I asked about a vacuum leak that I had. It was suggested that I replace the vacuum check valve and the gasket. I did that, but it didn't make any difference. Is there any other gaskets that can be the cause of that? Does it sound like my booster is shot? I want to try replacing any possible gaskets before having to buy a new one. Thanks for the help.
Low68
Build Thread |
I think it could be the booster they should be fairly cheep Buy a new one .
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Formerly yellow72custom
Take the booster vaccum hose off, and plug it or pinch it shut. Drive the truck w/o power brakes (just don't go very fast) and see if you still have a vaccum leak. Another way to check the booster is to get in the truck with the engine off, pump the brake pedal 5 or 6 times until it gets really stiff. Then put your foot firmly on the brakes, and start the engine. When the engine fires the brake pedal should sink in about an inch or two if the booster is working good.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
Thanks for the help. Other suggestions are welcome also. I want to get this fixed. Thanks
Low68
Build Thread |
Old Skool Club
![]() Join Date: Jun 2001
Hydro-Vac's do go bad. That is the vacuum booster that you are citing. With the engine running, does it run rougher when you press the brake pedal down? Do you hear a "Hiss"? If so, the odds are that the diaphragm in the booster is leaking. You can't fix it. You will have to use it as a core to get a replacement. Good luck.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
vac. leak
If you are running an automatic with a vaccum modulator check the connection at the fitting and at the modulator for dry rot.HF
