Old 11-17-2007, 08:00 AM   #1
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
One piece vs. two piece rear main seal
I remember this as a topic several years ago but couldn't find it with a search. Which type of seal am I suppose to use? I have a non-emissions bare bones crate. Also, I thought there was a way to get the oil pan off without out pulling the engine. Is this true. Any help or advice would be appreciated. Trying to get all the materials so I can get my truck running over Thanksgiving.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 11-17-2007, 08:46 AM   #2
ChevyDude
Re: One piece vs. two piece rear main seal
BBC...I just went through this when looking for my builder block...all Gen IV big blocks are 2 piece rear main seals. My machist/builder guy said get 2 piece. I would assume any small block out of our trucks era , are two piece also.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 11-27-2007, 09:58 PM   #3
speed
Junior Member
speed's Avatar
How old is the crate motor? GM changed from 2 piece seal to the one piece in the late 80's.
You can get the oil pan off without pulling the motor, it is tight though. For some more room you can unbolt the motor mounts and lift the front of the block with a cherry picker/ engine hoist.
Jeff J
86 El Camino
81 Monte Carlo
81 Regal
04 Colorado
speed is offline   Reply With Quote
Old 11-27-2007, 11:06 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
ona 4X4 I wouldn't think it's a problem getting it off... I don't think it can be done on a 2 wheel drive.
Old 11-28-2007, 01:10 AM   #5
earl87gta
earl87gta's Avatar
I had to trans ams one was a 85 and one an 86 85 had a 2 piece seal 86 had one Piece so if your engine is newer then 86 I would say one piece rear seal. if you cant get the oil pan off with out plulling the engine you may just need to remove the motor mount bolts and lift it a inch or 2 to give you enough clearnce to clear the cranke shaft if its not droping down enough and its not hitting the vrank it the oil pan may have a bafl in it to keep the oil from sloshing around and the oil pick up tube may be catching it.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 12-08-2007, 08:47 AM   #6
chris71
chris71's Avatar
for chevy small block they changed over in 87, along with vortec heads and roller lifters, maybe pontiac did it in 86? idunno. this is what my sbc rebuilding book said.
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 12-08-2007, 10:05 AM   #7
robin58
Pretty sure Vortec heads weren't seen on truck 350's until the 96 year.
robin58 is offline   Reply With Quote
Old 12-08-2007, 10:14 AM   #8
chris71
chris71's Avatar
sorry, i was talking about chevy in general
Old 12-13-2007, 04:47 AM   #9
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Not all center bolt cylinder heads are vortec. Im pretty sure the vortec name was used on the 4.3 or whatever size six cylinders in the mid 80s trucks.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 01-10-2008, 09:41 PM   #10
earl87gta
earl87gta's Avatar
My dads 86 vet had a one piece seal too.
Earl
Old 01-10-2008, 10:39 PM   #11
oldiron
oldiron's Avatar
Turn the engine over to #6 firing on the dist. this will turn the crank so the front jounal will clear the pan. Jack up the engine and put a 2x4 between the block and the mount or mount and the mount bracket. Had to do this on the road once. Takes about 2 hours of cussing.
oldiron is offline   Reply With Quote
