Old 01-10-2008, 07:23 PM   #1
Fishwacker
Never Give Up
Earlier Door Panels In My 72
Hi All,
I'm wanting to replace the original plastic inner door panels in my 72 3/4T with earlier flat metal ones. Any one been there/done that? Is it a straight swap or are there other parts I need to change as well? Any help or info is certainly appreciated. Thanks.
Fishwacker is offline   Reply With Quote
Old 01-10-2008, 07:35 PM   #2
powerbench
powerbench's Avatar
Re: Earlier Door Panels In My 72
don't quote me on this but the 72 doors have longer window regulator pins that stick out and the door opening handle is longer as well ....so the window crank and handle might be swinging in the wind unless you chenge the regulators and door latch mech.....some one else will correct me if i'am wrong...i hope
powerbench is offline   Reply With Quote
Old 01-10-2008, 07:43 PM   #3
72ChevyAZ
LWB Club
72ChevyAZ's Avatar
Correct!
I just got done doing what the OP is asking. I just ended up buying doors to a 68 and ordering new regulators for it too. The metal panels have 4 screws on the bottom to mount and a metal strip at the top that is seperate with I believe another four screws. You can mount the metal panels on the 72 doors, just need to make the extra holes (I believe).
72 Chevy Custom LWB
72ChevyAZ is offline   Reply With Quote
Old 01-10-2008, 08:44 PM   #4
Fishwacker
Never Give Up
Thanks Guys,
I was afraid of that. The real problem is those stinkin' thick door panels and the fat arm rest that gets all tore up as you reach for the left half of the seat belt. That designer sure had crap for brains. Why in the world would anyone think that decreasing the available space in a truck cab would be a good idea? DUH!!!
OK! I'm done venting now. Anyone know what the last year the shorter door hardware was used on? If it's available from the repop guys, it might prove to be the least amount of hassle both time and money wise. Thanks again for your help.
Old 01-10-2008, 09:18 PM   #5
lks dcvn
lks dcvn's Avatar
shorter stuff = any year before 1972...
sad but true - 72 is the only year for the longer door stuff.
it is available from the vendors - make sure to get the 67-71 door stuff (for the shorter hardware).
lks dcvn is offline   Reply With Quote
Old 01-11-2008, 01:10 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=273385
another thread n the first page on the same topic, look there for more responses
Old 01-11-2008, 03:27 PM   #7
72MARIO
72MARIO's Avatar
I Used The 72 Hardware With 67 Style Flat Pannels No Problem.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
