Merry Christmas to All on the Board!!
Did my best to glean this from the search options - no luck. I need to replace or repair my E-Brake pedal assembly. Do any of you have a drawing, scan or picture of how this is done and what steps to do it. Darn thing ratchets back almost every time I use it. (I'm pretty sure the teeth are shot.) I just don't want to attempt this in 17º temps at the Pick n Pull. Also, what years would work on a 1980 K10. Thanks!! - Dave
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
Re: Parking Brake Lever Removal
Hi, mine in my 73 was doing the same thing, so I tore the old one out, wich was a little tricky but fairly straight forward. After looking at it when it was out, the teeth were a little warn, but I thought I could drill a hole and add a spring, it should work. Looked good but didn't work much better when reinstalled. Anyway bought a new one from lmc, wich I wish I would have done to begin with, and its worth it. Also when working under dash I always say it would be smart to take out seat for more room but never do. good luck, bob
I don't have a scanner.I have a 85 service manual.It says(1)Place parking brake pedal or handle in the released position.(2)Remove nuts from the engine compartment on C,K and G models or bolts from the mounting brackets on P models.Take notice of the spacers on P models for reinstallation.(3) Disconnect the release Handle rod at the parking brake assembly end(C-K models).(4) Remove the bolts from the underside of the dash and lower the brake assembly(C-K-G Models).(5) C-K-G Models-Disconnect the cable ball from the parking clevis and remove the assembly.Installation. (1) Reverse the removal procedure.Torgure all bolts and nuts.After installing the clevis pin.Adjust the cable if necessary as outlined below.Torgure specs. To dash 100 in. Ibs.,To Ip,Kick panel,floorpan 100 in. Ibs.Cable Clips-Screws,Bolts 150 in. Ibs.
Thanks for the responses guys.
btw - great advice on removing the seat. 4 bolts and lost more room for us Men of Heroic Proportions - Dave
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club Last edited by wedgemon; 01-11-2008 at 01:47 PM. |
Robert Olson Transport
![]() Join Date: Oct 2002
i believe there were three bolts that were half inch heads when i pulled the one outta my 76
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
