![]() Join Date: Aug 2006
Fuel pump questions
I was looking into intank fuel pumps for my gas tank that i am building. I don't know alot about fuel pumps and had a few questions. First one is I am looking for an intank pump that will be pump enough gas to my LS1 motor. I will hopefully have around 600hp after all the mods. What GPH do i need? Also what is an evaporator? I went down to kragens to look at a few different fuel pumps and i noticed two plugs on top of most of the fuel pumps. The sending unit and pump is all in one. The guy at kragens told me that the other plug is for an evaporative system. I felt stupid. Is it relative to smog requirements? Do you recommend any specific fuel pumps? I want to find the pump i need then build my tanks depth accordingly. Thanks for the help and any comments are appreciated.
Josh
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
Re: Fuel pump questions
Here is the fuel pump i was looking at. Not sure if it will work though.
http://www.yogisinc.com/detail.cfm?P...NGP-4&Zoom=Yes
You should have a feed line and a return line. I can't tell from that picture, but you might have a third on that one (which would be for the evap system).
All the evap system does is control the vapors from the evaporating fuel in the tank. What year is the engine out of and vehicle? Does the fuel rail have 2 lines coming out or just 1? Edit: Actually reading that first one, it says its a vent. So it would just go up to the filler neck and enter there so the gas would flow in nicely.
1970 Chevy C10 "Under Construction" ![]() 2002 Chevy S10 V6 ![]() Last edited by st1x10; 01-10-2008 at 02:41 PM. |
Thanks for the info on the evap system. I was hoping someone had some insite on what fuel pump i should use or what i need to look for in the fuel pump.
Josh
ttt
The newer vehicles have a way to filter the fumes and send them on to the fuel system. Block off the evap line and run a breathing gas cap. Don't try to pass any Emissions tests though. That hose was going to the charcol cannister and it would suck the fumes into intake when computer told it to by means of a purge valve according to EPA regs. With the high pressure demand of the newer fuel injected system you gotta have the return line but don't need the evap line to make it run.
Added-- I would check to see if the LS1 needs more than 40 psi to run. I think it may be higher and if so that pump wont work. Check into fuel psi for that fuel induction system before purchasing.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched Last edited by DavesRide; 01-11-2008 at 04:51 PM. Reason: afterthough for fuel pressure |
![]() Join Date: Oct 2005
Seems to me (just off the top of my head), port injection motors need 50-60 psi fuel pressure. I believe 130 GPH pump will support 600 hp. Just make sure you size the lines correctly and any filters will flow enough as well.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
Do you think 3/8 lines for supply and return is sufficient? I havn't seen any pumps that will do 130gph. The highest i have seen are around 80-90gph. Thanks for the help guys!!!
JOsh
Here's an in tank pump that will support that HP level.
http://dagostinoracing.com/index.php...ducts_id=12079 I would probably go to a 1/2" fuel line for that hp level and the return can stay 3/8".
