01-11-2008, 06:09 PM | #1 |
How do you remove the collar from a tilt column
How do you remove the top collar from a tilt column? Will anything fall out? I will be installing a new turn signal switch.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
01-12-2008, 09:22 AM | #2 |
Re: How do you remove the collar from a tilt column
Ttt
01-12-2008, 09:28 AM | #3 |
It's a catastrophic success.
Here's all the pieces if they fly out everywhere.LOL
01-12-2008, 10:19 AM | #4 |
member #16
If you are referring to the cover piece, it presses on. Remove levers and use something soft and tap it off. I use a small piece of wood in the turn signal lever hole.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
01-12-2008, 01:57 PM | #5 |
Ok will give that a try. Thanks John.
01-12-2008, 02:06 PM | #6 |
I used a rubber hammer and hit it lightly while turning it over and over. Eventually it comes off.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
01-12-2008, 02:08 PM | #7 |
So its a press fit?
01-12-2008, 02:14 PM | #8 |
If you are talking about the piece that is labeled "cover" above, then yes it is a press fit.
01-12-2008, 02:18 PM | #9 |
It is a press fit. The service manual shows using a puller that catches the lip on the inside and pulls against the shaft.
I remove the tin housing by tapping it off after soaking the press fit area with penetrant since I don't have the tool that the manual shows. I have not run across one that cannot be easily tapped off. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
01-12-2008, 07:39 PM | #10 |
01-12-2008, 07:44 PM | #11 |
