Old 01-12-2008, 10:27 AM   #1
David Flores
David Flores's Avatar
trans cooler question
Probably a dumb question but...
Where is the best place to mount a transmission cooler?
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 01-12-2008, 10:33 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: trans cooler question
It kind of depends on the size. I have mounted them on the inside of the frame rail, bottom of the floor pan, front of the core support, and even under the running boards on the older cars. You want good air flow but just as important is to be protected from road debris.... Core support means longer lines but that is not all bad either.
LockDoc
Leon
Old 01-12-2008, 11:08 AM   #3
acl
acl's Avatar
Put mine on outside frame rail on pass.side. It is about where drive shaft goes into tranny. Hose up and over frame attached to bed bottom. Did not want to clutter up front anymore.
Gary
acl is offline   Reply With Quote
Old 01-12-2008, 11:40 AM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
Here's mine, totally hidden from view.
I put it on the front of the front frame crossmember. It just barely fit. It's as far to the DS as it could go. If I had used 90 degree fittings I could have centered it more, but I was cheap and used the "straight out" ones that came with it.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-12-2008, 12:25 PM   #5
timcos
Chief Honcho In Charge
timcos's Avatar
So if you add one of these with a TH350...does that mean you do not need to run the lines to the radiator?
That would be a nice thing.
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 01-12-2008, 12:41 PM   #6
s95930
A-Adam A-Adam
s95930's Avatar
Mine is in front of the radiator and behind the AC condensor.
70 3/4 ton GMC Camper Special
s95930 is offline   Reply With Quote
Old 01-12-2008, 01:53 PM   #7
Andy4639
Old member
Andy4639's Avatar
I stuck mine between the condensor and the radiator. I also ran the lines to the internal coolier also.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-13-2008, 03:26 AM   #8
67ChevyRedneck
Yes! Run them inline with a radiator. More cooling = happy tranny
I hadn't hooked mine up yet in the pic.
Jesse James
Project "On a Dime"
