Old 01-13-2008, 07:07 AM   #1
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: Replace Pan and Main Gasket - On Truck?
Originally Posted by LBJ View Post
So, now it seems I can't use the one piece pan gasket on my old block. Correct? The seal that's the worst is the front, but I suspect the rear is leaking too. Go the old way with individual seals for the front and rear mains, and separate pan gaskets?
Yes you can use the one piece pan gasket on an old block. What 87 stepper was referring to was the rear main seal around the crankshaft which went to a one-piece design in the late 80's.
With the pan gasket, the front seal that goes between the timing cover and oil pan came in two different thicknesses. Make sure you get the right one. Yours should be the thick seal if I remember correctly. You'll know immediately when putting it on if it's right or not.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
