Old 01-13-2003, 09:51 PM   #1
cacauba
STL-KKN
cacauba's Avatar
Wiper Motor
is there anyway to test a wiper motor prior to install? i've tried to connect all the electronics to it and then turn the key and engage the wipers but nothing happens. is there something else wrong? i've checked the fuse its ok. i replaced it just to make sure. did i just pull out my motor for nothing? please help. i sill have to get it back together before work tomarrow.
1969 C10 350/POWERGLIDE
1991 1500 EXTCAB 350
Formally: collegeK5er
cacauba is offline   Reply With Quote
Old 01-13-2003, 10:00 PM   #2
70cst10_05
70cst10_05's Avatar
umm get some wires and attach one end to a battery just an spare car battery if ya have one layin around and connect one wire to that and just start screwin w/ it and that should tell ya
1970 Chevy CST/10
1970 Chevy CST/10
1972 Chevy C/10
1972 Chevy Suburban K/10
2019 Silverado 2500 Duramax
Kevin
70cst10_05 is online now   Reply With Quote
Old 01-13-2003, 10:04 PM   #3
ozarkhippie
I'm not sure of this but try grounding the motor to the body. It may not have any thing to do with it, I can't remember if they ground through the wiring or not or ground from one of the mounting bolts.
Buy Sale or Trade
71 3/4 4x4
72 1/2 ton cheyenne 4x4
ozarkhippie is offline   Reply With Quote
Old 01-13-2003, 10:05 PM   #4
cacauba
STL-KKN
cacauba's Avatar
i've tried to touch a scap piece of wire to each terminal from the batterie but nothing happened. this led me to believe that it either had to be grounded or all the wires had to be connected. so i connected all the wires but didn't remount the motor, because it's a pain in the a$$ with an ac cab. but that didn't work either. any other thoughts?
Old 01-13-2003, 10:12 PM   #5
70cst10_05
70cst10_05's Avatar
it doesn't have to be grounded, cuz me and my dad did it one night, i don't remember how though, sorry.
1970 Chevy CST/10
1970 Chevy CST/10
1972 Chevy C/10
Kevin
Old 01-13-2003, 11:13 PM   #6
James67
New Member
wiper motor
You don't need to ground the motor. the power runs from the fuse block through the motor to the switch and when you turn the switch it goes to ground. hope this helps.
James67 is offline   Reply With Quote
Old 01-14-2003, 05:42 AM   #7
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
The switch can switch on power, or complete a ground, as it is doing in the wiper circuit. Wiper motor gets power at all times. On our series motors, there are 3 possible combinations, plus washer operation. For you techies, here are the combinations:
Park and off = lt blue and black connedted, (not grounded0
low speed = lt blue and black grounded
high speed = lt blue grounded
washer = dark blue grounded
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 01-14-2003, 10:52 AM   #8
cacauba
STL-KKN
cacauba's Avatar
thanks for all ya'll help, got it working about 11:30 last night!
Old 01-14-2003, 03:31 PM   #9
gman
K5er,
What was the problem?
72 Chevy SWB Custom Deluxe K10, 350/SM465, PS, PB, Fact. Air
2000 Harley...Wide Glide
gman is offline   Reply With Quote
Old 01-14-2003, 03:39 PM   #10
cacauba
STL-KKN
cacauba's Avatar
I used so electrical cleaner and really made sure the plugs were tight and for somereason the 3rd time i tried it, it worked. and so far it has been reliable. so i dont' know.
