Old 01-14-2008, 03:44 AM   #1
Silvius
Silvius's Avatar
Complete brake job needed, opinions?
Hello again
The 72 needs brakes in a bad way. Some of the components are probably original. Anyway, here is what the shop says it needs, and from what I looked at, I agree:
Front:
New pads and Rotors
New grease seals
Calipers need to be overhauled
Wheel bearings need to be repacked
Acuator adjusted
New brake fluid (flush and refill)
Rear: New pads
Resurface drums (or whatever it is they do)
Also it needs new (or remanufactured) master cylinder and hoses
All of this is going to add up pretty quickly, but I want it done correctly. The PO had done a lot of work, but left brakes off the list.
I don't have time to do it myself, unfortunately. I know that would save a lot.
Anyone care to tell me what they think it should cost? I'd like to get an idea before I hand over some $$$.
1972 Cheyenne Super
Silvius is offline   Reply With Quote
Old 01-14-2008, 04:03 AM   #2
lbpd719
Zappaphile!
lbpd719's Avatar
Re: Complete brake job needed, opinions?
Depends,
What is your safety worth to you? You might try shopping around to see if you can get a better deal. Costs vary too much from area to area. I know I can get the rears totally redone on my 3/4 ton for about 150.
Sweet truck, if it needs brakes and you can't do 'em yourself, get them done as soon as you can. Would hate to see another totaled truck thread..
1969 C20 LWB Camper Special - The Beater..
1998 Cheyenne V6 - 4/6 Drop - For The Son
lbpd719 is offline   Reply With Quote
Old 01-14-2008, 04:46 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I would never have the drums turned on a 1/2 ton truck of this era. They are pretty cheap at the parts store and these drums have been known to shatter. (not real common.... but not unheard of)
It may be cheaper to replace the Calipers instead of the labor to have them overhauled.
On that subject... why do you say they need overhauled? Are they sticking or something?
What actuator are you talking about adjusting up front?
When you do the back, it would be a good idea to get hardware and adjuster kits.
Old 01-14-2008, 04:53 AM   #4
LONGHAIR
Since I have no idea what the labor rates are in your area, over-all cost would be hard to say.
But as usual with me, that doesn't mean that there is nothing to say.
First, it's a big job, so it is going to cost. The best thing to do is get the most for your money.
Don't "service/overhaul" anything. Replace things like calipers, wheel cylinders, etc. Get a complete hardware kit for the rear. You get new adjusters and this replaces worn springs.
On a half ton truck, it is probably more cost effective to replace the drums. On a full floating 3/4 ton, turning may be better, if possible.
Parts like these are relatively cheap, labor on the other hand rarely is...
It is far faster to replace, which translates to less labor. The total cost may or may not change, but it is all new parts. You don't have bleeder-screw rust issues, etc... Same with adjuster screws. Break an old brake spring a few months after a major overhaul....you would be upset.
Wheel bearings might be an exception. The labor is pretty much the same either way, so if they are good, they are good. Replace them if they are worn.
Since you are doing everything from the master cylinder down, I would replace the rubber hoses too. They deteriorate from the inside to, so outer inspection is not all of the answer.
If you are doing a "super economy" job (and doing it yourself) you might "service" some of these things, because it is your time. Since you are paying, get the most for your money.
LONGHAIR is offline   Reply With Quote
Old 01-14-2008, 05:23 AM   #5
Silvius
Silvius's Avatar
Thanks for the input. Most everything will be either new or rebuilt. The few things that are rebuilt won't be an overhaul of my current parts, rather there are parts (calipers for example) that you can get new or remanufactured. I checked with two auto parts places, and asked them if they recommended against a refmanufactered master cylinder. Both places sold both versions and both said they have had the same return rate on new and remanufactured.
Since I am going to go through almost the whole set up, I will go with mostly new stuff but I may do a remanufactured part here and there. I don't know about the actuator; I'll have to ask about that. In answer to the question, one caliper is sticking.
Does $900 to 1150 sound reasonable for what I quoted above? That includes new rubber hoses. I likely will just have the rear drums replaced instead of the re-do, that will be part of the price. It seemed a little pricey to me, but all that stuff adds up and that will be money well spent for safety reasons. Mainly I am trying to find out if that price range is reasonable. I don't mind spending it; I just don't want to get taken on the price. I have checked with two shops so far, both of them have been around for quite a while, so that helps somewhat.
Thanks again for all the comments....
~S
1972 Cheyenne Super
Old 01-14-2008, 05:36 AM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
If labor in OK is like that in AR, you're going to have to plan on $150 per axle, or $300, plus drums, rotors and calipers. If your drum brakes need hardware (springs, etc.) that may (or may not) be extra...depending on the shop. When I did them, they were part of the job. Wheel cylinders are usually replaced nowadays. The labor and uncertainty of the rebuild is why. You don't want to rebuild a wheel cylinder if the bore is pitted. Cheaper and more reliable to replace, and quicker, too. Calipers don't usually get replaced, but it has had to happen at times. I rebuilt the calipers on my '60 TR-3, the first brake job I ever did. They were leaking and were easy to fix. I had to replace the calipers on an '83 F-100, because the pistons were sticking in the bore....they were phenolic and prone to failure as they heated up, I found. All I have had to do, or have done on my '96 GMC, was a simple (as I call it) brake job....turn the rotors, replace the pads, repack the bearings, replace the grease seals and pay attention to the sliding components being sure the pins are greased and contact points are free to move as needed. You want the calipers to grip the rotor properly and not have all the wear on one set of pads, instead of both.
As for the rear, turning the drums is best determined by the bore of the drum and whether it can be turned, or not. If the wear has taken the I.D. of the drum to the point that it cannot be turned and be within limits (that info is cast into the rear of the drum on the lip), you will have to replace them. I say "them" because you want both sides to be the same for the sake of stopping controllably. A drum that is too thin is suspect, but one drum that is thinner than the other, is also slightly larger in inside diameter, and has a hair more stopping ability (theoretically) and could cause that side to lock up before the other....had it happen with the front of a '62 Chevy II. Used to be you had to arc the shoes to fit the inside of the drum....they aren't always perfectly concentric. You want to be sure the rear axle oil seals aren't leaking either. If one of them leaks into the drum, that brake will grab and the wheel will lock. Don't ask me why grease makes the brake lock, it just does.
But I'm pretty sure these prices are about right for OK.
Member Nr. 2770
Old 01-14-2008, 05:36 AM   #7
Silvius
Silvius's Avatar
Also, a couple of more pictures I have from last year of the truck for kicks:
1972 Cheyenne Super
Old 01-14-2008, 08:50 AM   #8
fine69
fine69's Avatar
Why not find someone from this board in your area. And find out if they can come help you do it. Save some money, meet some board members. That is cool.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 01-14-2008, 09:10 AM   #9
WorkinLonghorn
WorkinLonghorn's Avatar
I don't know prices out there,but around here that would be a steal.
If you want to feel better about it,go into a Midas for their estimate.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 01-14-2008, 09:11 AM   #10
Silvius
Silvius's Avatar
ChevLoRay: Okie rates are roughly the same as Arkansas. Some good input and advice that I will take, thank you.
Fine69: That is an idea that I may try in the future. No time for me to even help turn a wrench right now. However, paying a good mechanic to do it in my garage (or his) could save me some $$$ on future work.
WorkinLonghorn: Yes, I had the shocker Midas estimate on my '89 many years ago. Never again! They take overpricing to the extreme.
1972 Cheyenne Super
Old 01-14-2008, 03:57 PM   #11
wibilly
wibilly's Avatar
i think i would take a day off to save $500 in labor costs but thats just me
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 01-14-2008, 04:31 PM   #12
Longhorn Man
When you look at it that way.
Unless you make $500 a day at work... I'd call in sick and do it myself.
Assuming you do have the tools and know how to do it. Otherwise it's all moot.
Old 01-14-2008, 04:36 PM   #13
89 crew
One thing you want to know on those prices are what grade of rotor and drum they are going to install. Most shops around use the cheapest parts they can get. The problem with those parts are they are at minimum spec the day they were made. You can't turn a brand new price maker rotor or drum. So the parts they put on may not have as much iron in them new as you have in the old.
89 crew is offline   Reply With Quote
Old 01-14-2008, 05:18 PM   #14
Longhorn Man
a lot of the upgrade rotors and drums are not much better. Heck, stock rotors (esp on fords) are REAL bad these days. Almost like they are crap metal plated with better rotor material. (mostly rotors, not so much an issue on drums)
Old 01-15-2008, 12:58 AM   #15
El Jay
Gone to greener pastures
A lot of rotors are "1 time use, only." There isn't enough material there to turn, even w/ factory rotors.
As an aside, I broke a ball joint on my '69, right before going on vacation (talk about lucky) a couple years ago. I didn't have time to do the work myself. So Ihad the truck towed to a local front end/brake shop for repairs.
I told them, while they were at it, check the brakes & do what was needed.
I ended up w/ a 4 wheel brake job, which didn't surprise me because I was having "issues" w/ stopping in a straight line, etc.
2 ball joints, idler arm, 4 wheel brake job & some other misc. parts like spring kits, etc, was about $1200.
I said all that, just to say this.
About a year later, I was losing brake fluid.
So I pulled the wheels/drums to look for the leak.
It ended up I had a stuck self adjuster.
"No big deal", sez I, until I went to knock the "knock outs" outta the drums. They weren't there.
Adjusting the brakes just became a minor pain in the butt because they used cheaper, imported parts.
It isn't really a big deal. It is just a pain.
That's just my .02 this morning.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 01-15-2008, 03:03 AM   #16
72freak
Rottenwood Garage Member
72freak's Avatar
~S
That sounds about right for a COMPLETE brake sytem overhaul......keep in mind you could do it in a weekend for probably $400 to $500
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 01-15-2008, 05:05 AM   #17
Longhorn Man
As far as I know, those are the ONLY ones avalible. They are missing the hole for the adjusters, and also the lip for the spring on the outter edge.
Old 01-15-2008, 05:29 AM   #18
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Seems like I remember some brake drums that had knock-outs on them to allow for adjustments from the wheel side, instead of going through the backing plate. That may explain the reason for the lack of access on the backing plates.
Member Nr. 2770
Old 01-15-2008, 05:59 AM   #19
Longhorn Man
stock ones had holes, the cheap replacement ones did not.
Old 01-15-2008, 06:06 AM   #20
89 crew
You might check Wagner brand rotors they might still have the holes or at least a knosk out to make the hole.
Old 01-15-2008, 07:01 AM   #21
72freak
72freak's Avatar
I have swapped to WAGNER for everything!!!!
Old 01-15-2008, 07:23 AM   #22
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Wagner used to have the knock outs, but the last set of drums I got for the 72 did not have them, Wagner has two lines the BD series supposedly made in the U.S., and the Guardian series made in China. I looked at both for the knock outs and neither had them. Also you would be money ahead if you buy all of the parts yourself and have them put the parts on the truck, if you let them buy the parts the shop will charge you list price, which is about 30%-45% markup over the orginal price.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 01-15-2008, 09:31 AM   #23
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Okay, here's an argument that some may not like or understand but suppose the restaurant you like to dine at charges more money than you like to pay.
So, you go to the grocery/delicatessen/etc., and buy what you want to eat, then take it to the restaurant and let them cook it and serve you. Wanna know what it's gonna cost you, IF they will do it? Same price as if you ate their groceries that they prepared for you.
If you're gonna take the parts to the shop to be installed on your vehicle, YOU and the shop owner/mechanic had better be on very good grounds. Then, if he/she does the work, don't expect any warranteed parts to be also replaced by them for no more money.
When I was in possession of my second car, a '56 Merc, the flex plate developed a "rattle". My mechanic uncle told me what I needed, and I then bought a new flexplate from a dealer, for $12. I went to a garage he recommended, taking the new flexplate. The labor to put it in? The same $43 that I would have paid if I had not taken any parts. The shops are in business to make money and they make some of it off of the mark-up in parts. We don't always have to like it, but they have families to feed, too. Oh, this was in '66. I was making $1.15/hour bagging groceries for Kroger. It took most of my take-home pay for 2 weeks of work, figuring I was working on average 25 hours a week.
Member Nr. 2770
Old 01-15-2008, 09:54 AM   #24
El Jay
Great analogy.
Old 01-15-2008, 10:31 AM   #25
cdowns
cdowns's Avatar
i'll give anybody a hundred dollars for posting a picture of a 71-72brake rotor that has a knockout for adjusting brake shoes
