Anyone have a problem in third gear -
on your SM465, having the shifter hitting the dash? I've bent it down once, but it still hits when I shift into third. I'm thinking I'll have to bend it even further, and then put another bend upwards, so it'll shift a little easier. It doesn't seem like it should be hitting the dash. Anyone else run across this?
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
Re: Anyone have a problem in third gear -
i think mine is the stock shifter bends and it has room on my truck.
ttt I might mention that it was a three speed, and it's a '67 with an sm465 out of a '72.
Is the engine and trans mounted to far forward? It should still clear. Maybe wrong shift lever? Here's a pic of my shifter.
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() Last edited by OhioDan; 01-15-2008 at 01:05 AM. |
maybe your trans is getting sloppy and its time for a rebuild?
-Jake 1962 ![]() ![]() Interior- Puke green dash, brown vinyl seat from an 87. Exterior- Rust 1993 ![]() If you have a truck everyone is your friend. When they need to move. |
![]() Join Date: Sep 2005
stop if your useing an after market kit mine hit the dash borad all the time when i went into second min was just a rod 2 holes in it i just turned it around and it was fine
Seems to be a stock shifter, and the tranny's pretty tight. It doesn't hit hard, but it hits - I'll probably just put another bend in it.
nm i have a diffenrent 3 speed mine was oringaly on the column so i have an after mark shift kit. there might be an adjustment somewhere to fix it i hope someone will pipe in with an answer for you
I am a Referee of life.
Just a thought and I really don't know but is there a difference between the 6 cyl and V8 shifters?I'm thinking the bends may be different since the 6 mounts differently then the V8.It may mean the shifter is an inch or two different causing the problem.Of course that's also assuming you used a tranny from the other style motor.Hope this made sense.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 01-15-2008 at 05:05 AM. |
Yeah, it does. I just noticed Ohio Dan's shifter has two bends in it - mine only has the one near the bottom. Maybe that's the porblem - just tweak the bottom bend a little more, and put a top bend in it. I just don't understand why it only had the one bend. I'm not sure that the tranny came out of a V8, but the hump is for a V8, and the shifter is centered in the hump. In the sixes, the hole is further back. Maybe that is the problem - the tranny was from a six, and the hole being further back never had a problem with hitting the dash with the shifter.
