Old 01-16-2008, 01:23 PM   #1
snj8198
snj8198's Avatar
wiper motor ?
hi guys, im in the process of making some nickel and dime repairs. my '71 has a 2 speed wiper motor, slow and slower. what do you recommend as a replacement? parts store oem? LMC? Year One? other? is there an after market unit that's faster or a motor from another vehicle that may work better than the original?
thanks ahead! -steve
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 01-16-2008, 01:59 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: wiper motor ?
I have never done this *YET*, but if you had a good one, you'd probably find that it is too fast on high.
I can't recomend a place to buy one.
Old 01-16-2008, 05:29 PM   #3
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: wiper motor ?
I put one in from a Jeep Wagoneer. The switch had a delay function. The intallation is not for the faint of heart as it requires trimming the mount under the dash and changing the arm the wiper mechanism connects to.
However, it works well and I like the delay function.
low'n slow is offline   Reply With Quote
Old 01-16-2008, 05:38 PM   #4
'71c204x4454
'71k204x4454
Re: wiper motor ?
Here is one thing you could do to upgrade your wipers and it is not hard to do. It won't make it any faster but will give you delay wipers. http://www.carolinaclassictrucks.com...wiper-kit.html
1971 K20 4x4
1964 buick skylark convertible
'71c204x4454 is offline   Reply With Quote
Old 01-16-2008, 05:39 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: wiper motor ?
It won't cost you anything to clean the terminals and make sure the motor is grounded good.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-16-2008, 05:43 PM   #6
clemson71guy
clemson71guy's Avatar
Re: wiper motor ?
i bought one from auto zone it think it was like 50 bucks.
you will need to keep the plastic vaccume thing on the side because it doesent come with one.
clemson71guy is offline   Reply With Quote
Old 01-16-2008, 07:03 PM   #7
Longhorn Man
Re: wiper motor ?
the vacume thing is the washer pump... not vacume.
Old 01-17-2008, 02:11 AM   #8
snj8198
snj8198's Avatar
Re: wiper motor ?
thanks for the input fellas.
Vet- i cleaned the electrical terminals and ground strap but no difference. i think 31 years of service has just wore it down but thanks for reminding me to try the basics first.
Low'n- i'll keep your Wagoneer motor as a plausable back up idea if i don't find a decent bolt on item. a little effort to make it work dont scare me. i think?!
'71C20- i have never been to that site so thanks for the heads up on it. that set up is nice but too nice for my rig!
i have other items on my shopping list for LMC, but i hate to order a motor from them just to find there's no speed difference. probably do a parts store purchase here, try it and see if performance is increased. Longhorn, if i stumble upon something good i'll pass it on to ya. thanks again guys. -steve
Steve
Old 01-17-2008, 05:51 PM   #9
low'n slow
low'n slow's Avatar
Re: wiper motor ?
I have some pictures I can email if you decide to go this route
Old 01-17-2008, 07:16 PM   #10
Longhorn321
Size Matters
Longhorn321's Avatar
Re: wiper motor ?
[QUOTE=snj8198;2532016]thanks for the input fellas.
Just one little thing to add to what VetteVet said...If you have a DVOM, check the voltage at the motor when it's on high speed. There could be a voltage drop somewhere other than at the motor or ground. You should have close to battery voltage on the high speed winding (make sure you are grounding your meter to a good ground like the neg. post of the battery).
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
Old 01-18-2008, 06:45 AM   #11
Longhorn Man
Re: wiper motor ?
When messing with these, remember, the motor always has power, it is switched on the ground side.
So it dosn't matter what the switch is set on, you should always have 12 volts or so.
Old 01-18-2008, 07:57 AM   #12
snj8198
snj8198's Avatar
Re: wiper motor ?
12 volts? ok...i'll check.
Steve
Old 01-20-2008, 06:41 AM   #13
Longhorn321
Size Matters
Re: wiper motor ?
...That's me showing my frustration! I know a lot about electricity in general and a whole lot about electricity in BMWs but unfortunatly, I know less about how Chevy used to do things (less practice). I did not know that they changed the resistance on the ground side (Thanks Longhorn Man, I'm sure that info will come in handy some day!). The theory is the same though, you should have a 12 volt drop across the motor on high speed. Just put your red lead on the power side and the black lead on the ground side and you should see 12 volts. If ya don't, move your black lead to the neg. post of the battery and see if you have 12 volts then. If ya do then you have too much resistance somewhere on the ground side (switch?). If you still don't have 12 volts, then you have too much resistance on the power side. Let us know what you find and if you need more help.
...WOOOO HOOOO!!!!
