Old 01-16-2008, 08:39 PM   #1
mateo1279
mateo1279's Avatar
Coil cutting Q
Hello-
When cutting coils, does one have to cut a full coil off? Is it possible to just cut 1/4 coil until you reach the desired hieght? I'm trying to balance things out better untlil I can afford a better suspension solution...
Thanks,
Matt
1962 Chevy Fleetside
283/TH350
mateo1279 is offline   Reply With Quote
Old 01-16-2008, 11:48 PM   #2
63 & 64 Bowties
and a few others
Re: Coil cutting Q
I assume you're talking about front coils. I cut two turns off my 63, but if I remember right, the lower control arm has a notch for the end of the coil to rest in, but the upper doesn't. So half cuts will work.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 01-17-2008, 02:11 AM   #3
70c10
67-72 Addict!
70c10's Avatar
Re: Coil cutting Q
Originally Posted by mateo1279 View Post
Hello-
Thanks,
Matt
Yes, you can cut partial coils off the bottom of the front coils even though some people say only cut full coils. I recently cut less than one full coil but more than 75%. My last pair of coils I cut 1.25 coils.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-17-2008, 08:49 AM   #4
mateo1279
mateo1279's Avatar
Re: Coil cutting Q
Actually, I was thinking rear coils... Is that dumb?
I have a torsion bar front and can get that pretty low...
283/TH350
Old 01-17-2008, 11:21 AM   #5
63 & 64 Bowties
and a few others
Re: Coil cutting Q
You really can't cut rear coils. They're tapered on the ends and have retainers attached. Just go with a car coil. Some members here use Jeep, I have 70's Chevelle in the rear of my 63
Old 01-17-2008, 11:34 AM   #6
mateo1279
mateo1279's Avatar
Re: Coil cutting Q
Perfect! I guess I should have been more specific in the first post. Are you using chevelle rears on your truck's rear or cheelle front coils in the rear?
283/TH350
Old 01-17-2008, 10:10 PM   #7
63 & 64 Bowties
and a few others
Re: Coil cutting Q
Chevelle rears in the rear. They have a similar (not exact, but close enough to work) taper on the ends. I'm sure the Jeep springs would be a lot eaiser to locate. Maybe someone who uses them could tell you which ones they used, Wrangler maybe? I just had the Chevelle springs so I used them.
Old 01-18-2008, 10:41 AM   #8
wibilly
wibilly's Avatar
Re: Coil cutting Q
i read a thread on here somwhere where somone used ford tauous wagon springs for a drop of 6" i harvested a pair from the yard but havent tried them yet
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 02-03-2008, 03:08 AM   #9
slepysal
slepysal's Avatar
Re: Coil cutting Q
I used jeep coils on my 60 droped it nice !!
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 02-04-2008, 02:48 PM   #10
slammed1
1972 Chevrolet SWB
slammed1's Avatar
Re: Coil cutting Q
I placed jeep coils on a friends 69 also and they worked great. You would be surprised to see that many companies coils arent that expensive anymore and you get exactly what your looking for drop wise.Check some board vendors for rear coil prices,and dont forget about rear blocks for a rear drop.
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 07-13-2011, 06:15 PM   #11
83highsierra
83highsierra's Avatar
Re: Coil cutting Q
so can you cut the front springs put them back in and go on. im doing a rear flip kit and i want the front to sit a lil lower than stockto nida level out so i was thinking cutting one coil. do i "have" to get drop spindles?
83highsierra is offline   Reply With Quote
Old 07-13-2011, 09:19 PM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Coil cutting Q
Originally Posted by 83highsierra View Post
so can you cut the front springs put them back in and go on. im doing a rear flip kit and i want the front to sit a lil lower than stock to nida level out so i was thinking cutting one coil. do i "have" to get drop spindles?
On your 83 if you cut one coil you will get +/- 2" drop. That will still leave you sitting nose high if you do a flip kit. You don't "have to" get a dropped spindle, but I would. I prefer to get as much drop as possible from spindle since it has no impact on the ride quality. From there I like to drop it with a cut spring
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-13-2011, 10:03 PM   #13
Indian113
Indian113's Avatar
Re: Coil cutting Q
I used Jeep TJ rear springs on my 64,dropped it about 4 inches. You can get them pretty cheap if you go to a 4 wheel drive shop. I paid $30.00 for mine
Indian113 is offline   Reply With Quote
Old 07-14-2011, 12:01 AM   #14
83highsierra
Re: Coil cutting Q
I actually just ordered the axle flip bracket from a vendor on here and i also just got two brand new leaf springs
Old 07-14-2011, 10:36 AM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Coil cutting Q
To save confusion I replied to your posts here- LINK
Articles-
"Refining Sierra"
