#26 |
Re: cannot seem to get any help on calipers...
hey guys, still no luck and no dice on hearing back from the vendor.
#27 |
I say post the Vendors name then so everyone else has fair warning of the customer service they can expect if they choose to deal with them.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
#28 |
The vendor name is GMCPauls. Im very dissapointed, because I was stoked that I scored a good deal and it has now turned into this.
If I just can get my truck up and going i'll be happy. |
#29 |
Man, that sucks. But that's the very reason I went with 72 spindles and calipers/hoses/pads/rotors/tie-rod ends, etc. Everything can be bought from one of several local parts houses.
#30 |
![]() Join Date: Nov 2001
I had a small issue with him, but we discussed it and everything turned out... hope all works out...
Call me if I can help.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
#31 |
There are heavy duty and light duty set-ups on the 80 model trucks.. I ran in to the same problem when I ordered drop spindals.. The calipers, spindals, rotors, brake lines, bearings and races, are different..
I would just go to a gm dealer and run your trucks VIN and find out what brakes it has...
Chickenhouse chopshop 81 rcsb chevy bagged LS1/4l60E(under the knife) 94 ecswb L92 headed LQ9/ 4l80E(waiting to go under the knife) 78 rcsb chevy LQ4/4L80E |
#32 |
DRUMROLL PLEASE-
Problem solved. The caliper is from a 79-95 truck. Thanks guys. btw- still have not heard back from vendor. buyer beware |
#33 |
Heavy duty rotors will be 1.25in thick. The light duty will be 1.0in thick. The H.D. will also have a 1.375 dia. inside diameter inner bearing and the L.D. will have a 1.25in I.D. inner bearing.
