Old 01-17-2008, 01:40 PM   #1
big mike
402 HP and spec question
Can anyone tell me why the 1972 BBC 402 has such a low horsepower rating compared to the 1971 402 motor when both have the same casting numbers on blocks and heads. Is it compression ratio, camshaft, or what?
Will a change in the camshaft on a stock 1972 truck 402 improve the horsepower dramatically? Thanks
big mike is offline   Reply With Quote
Old 01-17-2008, 02:37 PM   #2
JimKshortstep4x4
Re: 402 HP and spec question
Welcome to the 67-72 truck board from West Michigan!
The horse power rating was changed from "gross" to "net" for the 72 and newer years. The engines are basically the same only the rating system changed.
A cam by itself will probably not help performance because of the low compression the engine has.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-17-2008, 02:38 PM   #3
cdowns
cdowns's Avatar
they changed the way they reported horsepower for insurance reasons back in the muclecar era so your 72 probally has just as much horsepower as the 71 i doubt theres any noticeable differance
Old 01-17-2008, 02:43 PM   #4
big mike
Thanks for the replies. I was about to sell this motor off cheap because I thought it was just a boat anchor. Now I feel better about spending the money for a new valve job, a new cam and lifters and an aftermarket intake manifold.
Old 01-17-2008, 07:41 PM   #5
ofnaman
ofnaman's Avatar
I just (2 weeks ago) rebuilt my '70 402 and did a valve job on it and put a good cam in it. I also put an aluminum intake on it and HEI. Same crappy holley carb. I only honed the cylinders and reused the stock pistons. I cannot believe the power difference. If it was not for the crappy carb this thing would run great. Before the rebuild it ran good, I rebuilt it because the #1 cylinder intake valve lifter broke and I wanted to go through it anyway. I would never trash a usable 396 or 402, they are great running engines, and you could easily make a ton of power out of them.
A sweet 2000 Deville.....
ofnaman is offline   Reply With Quote
Old 01-18-2008, 02:44 AM   #6
streetstar
streetstar's Avatar
yep -- its a boat anchor alright. I'll be there tomorrow with $75.00 in my pocket, so have it swingin for me --
just kidding - any big block is worth keeping --
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
Old 01-18-2008, 07:25 AM   #7
big mike
Darn...I misplaced that chain. I guess I'll have to invest some money into it and give it a topside rebuild. Now I need to decide what size cam to put in it without getting crazy.
