Clutch and Clutch Linkage
Does anyone have any suggestions on what to do with the clutch?
I have a 350 and a stock 3 speed transmission with 3 on the column. We cannot get the clutch to engage even with the linkage adjusted all the way. We have managed to get the shifter linkage right but cant figure out the clutch. Any pictures or tips would be great |
Re: Clutch and Clutch Linkage
Without pics or more detailed info on the situation it is difficult to give good ideas, but off the top it sounds as though there is not enough travel in the linkage - when pedal is released there is not enough rod travel to enable the pressure plate/disc/flywheel to mate. If it is not a rod travel or rod length issue, then it is probably internal to the clutch mechanism/fork/release bearing aspects. This is just a WAG with the info available.
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
your problem might be with the clutch fork pivot ball. you can adjust it on the bell housing. it will be located on the upper drivers side of the bellhousing, on the flat surface that the tranny/bellhousing mate. it might be partially covered by the transmission mounting flanges.
did you replace the clutch or flywheel or anything eles? |
There are two style throwout bearings, a "short" one and a "tall" one which would make a difference in the travel ???
Rob |
The throwout bearings are matched to the pressure plate. The long one if installed where a short one is needed will keep the clutch from engaging.
The short one if installed where a long one is needed will keep the clutch from releasing. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
I suppose you mean that you can't get the clutch to dis-engage?
Do you have the right clutch fork? |
well we bought a new fork and it matches the old one perfect and we have a whole new clutch.
The clutch wont engage at all. We can get it in neutral but if we put it in gear and press the clutch in the truck wont move. From talking to the auto tech teacher he thinks its the throw out bearing. My friend is going to check that today as i have come down with the flu. |
#8 | |
![]() I think Eichorst69 and JimKshortstep4x4 are on the right track. Hard to explain without pics though. There's 2 different styles of throwout bearings and 2 different styles of pressureplates that match them. (Assuming we're talking about diaphramn pressure plates) A long style throwout bearing mates to a flat style pressure plate, and a short stlye throwout bearing mates to an extended finger style pressureplate. Assuming a new clutch installed? I've also seen the clutch disc installed backwards. Wrong side facing the flywheel. But this causes the clutch to not release.
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
