Will 73 Blazer steering work?
Will a 73 blazer power steering box and column fit into a 69 GMC 3/4 ton?
Richard Dobson |
Re: Will 73 Blazer steering work?
The steering box is a direct swap but the column would need installation work as it is larger and bolts up differently. The column would also look out of place since it will have the ignition switch in it.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 01-19-2008 at 07:38 AM. Reason: wording |
WTB this ad
Just remember that you can't interchange them 2wd to 4wd.
Mine wasn't. It bolted up and fit just fine, but my '69 didn't have an adjustable drag link, so I could turn really really sharp to the right, but it would take 40 acres when I'd turn to the left.
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
