Old 05-19-2002, 11:07 AM   #2
Scrub
Collector of rusty Items
Scrub's Avatar
Post
I'm interested in how you are going to do this swap as the frame is too wide for a regular dual axle (Normally)
What axle do you have that will fit?
As far as performance, You will obviously spin the squirells faster. What size tires are you going to be running? How are you handling the different brakes?
Scrub
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
Scrub is offline   Reply With Quote
