reverse lights!
any one have step by step instructions on how to wire up the reverse lights. including picture diagrams. i need to know all switches and locations. i would like to start under the dash and see if all components are in place and find what is or is not working. as of now i have them wired to a toggle switch. i want them to work with the shifter on the column.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
Re: reverse lights!
Since you have a toggle switch hooked up, all you have to do is hook the two wires to the factory back up
light switch to make them work with the column. Do you have a stick or automatic? Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Re: reverse lights!
mine is automatic, where is this factory backup light switch?
Re: reverse lights!
The backup light switch on the automatics is part of the neutral safety switch which is located on top of the column close to the floor.
Jim
Re: reverse lights!
thank you, i will check it
| Bookmarks |
