Old 11-12-2007, 08:08 AM   #1
Ironhorse
Ironhorse's Avatar
5 Lug Disc Brake F/S-Ks.
Complete 5 lug disc brake crossmember from '71 2wd pickup. Hub to hub with coils, upper and lower a-arms, calipers, spindles, dust sheilds. $125 or offers? Must be picked up, 30 miles south of Wichita, Ks. Will break down to just the spindles, dust sheilds, calipers and ship on your cost. Need this gone but hate to scrap it.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 11-14-2007, 01:23 PM   #2
ksucatz
Suppose to be workin........
ksucatz's Avatar
Re: 5 Lug Disc Brake F/S-Ks.
What kind of shape are the brake parts in? Are the rotors and caliper original?
Brent
'68 C10
'70 C10
'72 LeMans
"03 Trailblazer
"Stupidity is like a skill, some are born with it and some develop it over a period of time."" Author unknown
ksucatz is offline   Reply With Quote
Old 11-14-2007, 05:20 PM   #3
Ironhorse
Ironhorse's Avatar
The truck was running when it was trashed in a roll over, not a straight piece of sheet metal on it when I aquired it. Brakes were still operating at the time. As far as I know the caliper brackets are stock original, not sure about the rotors. They may clean up with a turning but I can't say for sure. Been setting for awhile outside. At the least if I were using this for a disc brake conversion I would replace the rotors and pads.
Wellington, Ks
Old 11-14-2007, 08:16 PM   #4
andrewt2
andrewt2's Avatar
how much for front spindles rotors and calipers shipped to 66414?
andrewt2 is offline   Reply With Quote
Old 11-14-2007, 09:28 PM   #5
Ironhorse
Ironhorse's Avatar
Not sure what shipping to 66414 zip would amount to. Will have to do some figuring on that, not sure what the weights involved would be. Would really like to sell as complete crossmember for disc conversion but will try and get you some sort of a realistic shipping quote for following parts:
spindles, dust shields, caliper brackets and bolts, and rotors if you want them. Anything else you may want for a conversion? Do you want the upper and lower A-arms?
Might want to replace the rotors as I am not sure how well they will turn within tolerance.
Give me some time to try and calculate the shipping weights and costs and I will get back to you.
Wellington, Ks
Old 11-15-2007, 07:41 AM   #6
andrewt2
andrewt2's Avatar
i shouldnt need the a arms i should be able to use mine. just the spindles rotors calipers/bolts, and dust shields u might see how much weight is saved without the rotors. if gas wasnt well over 3 bucks a gallon id just make a drive to come on down but gas prices are killer!
Old 11-15-2007, 01:35 PM   #7
ksucatz
ksucatz's Avatar
I will be down in Wichita the first week of December or so to drop the wife at the airport. If the assembly is still together, I would be interested. Let me know.
Brent
'68 C10
'70 C10
'72 LeMans
"03 Trailblazer
Old 11-17-2007, 06:42 PM   #8
Ironhorse
Ironhorse's Avatar
Since the crossmember is still unspoken for am hoping this post gives needed info for everyone.
andrewt2, Sorry to take so long but it took a bit of time to get shipping weights and a shipping quote. Total weight of each disc brake setup per side is 65 lbs. boxed. That is the rotor, spindle, caliper, dust sheild and all related hardware and bolts for the flex lines and such. After looking at the rotors and spinning them I think they would turn just fine. The pads on the discs rubbed the surface enough that I can not see any deep pits or such. One rotor needs a stud but that's no big deal to replace. UPS shipping to Topeka 66614 zip code residential for two boxes at 65 lbs. each is $21.50 per box for shipping total of $43.00. Add in the $125 for the disc brake parts setup totals $168.00 to your door.
ksucatz, Disc brake crossmember is still complete as did not have to break it down to get the weights needed for shipping quote. Depending on what day and time you bring your wife to Wichita for flight I can help by bringing the crossmember to Wichita in my truck since I work in Wichita and live in Wellington.
Wellington, Ks
Old 11-18-2007, 12:04 AM   #9
huero
1969 Short, Fleet, and Beat
huero's Avatar
How much for the disc brakes to 90807 (Long Beach, Ca.)?
huero is offline   Reply With Quote
Old 11-18-2007, 07:18 AM   #10
Ironhorse
Ironhorse's Avatar
hureo, According to the UPS website shipping to Long Beach, Cal. 90807 residential address is $91.00. Four days shipping time. Little further to Cal. than Topeka, Ks. LOL That is for both sides weighing in at 65 libs. per side, two boxes total cost to your door $216.00
Wellington, Ks
Old 11-18-2007, 07:41 AM   #11
andrewt2
andrewt2's Avatar
Ironhorse-
I'll have to pass for now, just dont have the funds till next pay day other wise i'd be all over them i appreciate the help sir!
Old 11-18-2007, 05:15 PM   #12
Ironhorse
Ironhorse's Avatar
andrewt2, No problem for the time spent. No one has spoken up and said for sure "I'll take it" so it may well still be here when payday rolls around again.
Wellington, Ks
Old 11-18-2007, 05:22 PM   #13
huero
huero's Avatar
Thanks for taking the time Iron Horse. Shipping takes all the fun out it. Wish you lived closer. I would also be all over it.
Old 11-23-2007, 11:45 AM   #14
70chevytruck
Do you still have this for sale? If so, I would be interested in the upper and lower control arms and spindles. I figure to buy new rotors and calipers etc.
Thanks.
70chevytruck is online now   Reply With Quote
Old 11-23-2007, 05:36 PM   #15
Ironhorse
Ironhorse's Avatar
Still have the complete crossmember all in one piece at the moment. Will get a shipping quote for you soon as possible for the upper and lower a-arms, disc brake spindles, backing plates (dust shields) and the calipers (with the bolts) if you want them for the cores. Might be cheaper to you using these calipers for cores if you have to pay core charges.
Wellington, Ks
Old 11-25-2007, 09:41 AM   #16
Ironhorse
Ironhorse's Avatar
70chevytruck, PM sent with info.
Wellington, Ks
Old 12-10-2007, 06:24 AM   #17
Ironhorse
Ironhorse's Avatar
Cross member still available, complete 5 lug disc brakes, $125. Would be best for local pick up as shipping prices make it tough.
Wellington, Ks
Old 12-19-2007, 09:48 AM   #18
ksucatz
ksucatz's Avatar
Well, I was down last week, but with the weather, I figured I better wait. Don't know when I will get that way again. After the first probably. If you are not in a hurry, I will look then.
Brent
Brent
'68 C10
'70 C10
'72 LeMans
"03 Trailblazer
Old 12-19-2007, 01:15 PM   #19
Ironhorse
Ironhorse's Avatar
Brent, no problem at all. Crossmember is still complete and hasn't budged an inch. Have to agree with ya', was kind of a crappy weekend. Perhaps we can get together on it after the holidays.
Wellington, Ks
Old 01-21-2008, 08:07 AM   #20
Ironhorse
Ironhorse's Avatar
Well, Brent and I were able to get together today and the disc brake crossmember has a new home. Thanks for the purchase Brent, hope it serves you well.
Wellington, Ks
Old 01-21-2008, 11:27 PM   #21
ksucatz
ksucatz's Avatar
I will put the disc brakes to good use. Thanks for working with me.
Brent
'68 C10
'70 C10
'72 LeMans
"03 Trailblazer
