Old 01-21-2008, 08:32 AM   #1
Pl4yboy
Freeeeee Mason...
Pl4yboy's Avatar
Center Caps, Beauty Rings
Okay, I have these old 15" rallies from before I put on my 22's and I was wanting to paint them black and put chrome Tri-Bar center caps on them. Does anyone know where I can find new ones that will fit these wheels? I could use some beauty rings too. My truck isn't a 4x4 but a PO slapped those ugly caps on there.
I really just want something pretty to slap on every once in a while... especially in the dirty winter months. I haven't had time to clean my wheels in a month and the chrome is looking pretty dirty.
Pl4yboy is offline   Reply With Quote
Old 01-21-2008, 12:17 PM   #2
jamesi20
jamesi20's Avatar
Re: Center Caps, Beauty Rings
I got my trim rings here http://cgi.ebay.com/ebaymotors/ws/eB..._promot_widget
jamesi20 is offline   Reply With Quote
Old 01-21-2008, 12:47 PM   #3
Pl4yboy
Freeeeee Mason...
Pl4yboy's Avatar
Thanks. I've found quite a few places to get the rings, but none to get the center caps I want... anyone else have any ideas?
Old 01-21-2008, 02:42 PM   #4
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
OK.....here you go:
CHEVY-SPINNER-KIT-KNOCK-OFFS-3-BAR-WHEEL-CENTER-CAPS
this looks about the same height as the OEM center caps? I was thinking take the knock off apart, put the stand under the center cap (with a center hole pre-drilled in it). Then just screw/bolt the knock off top thru the center cap to the mount? Or, do it the way they say (from behind )... and use a spacer?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-21-2008, 02:52 PM   #5
Husker
Husker's Avatar
What kind of shape are the 4x4 caps you have pictured in? May be interested in them, I have a 4x4.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 01-22-2008, 12:57 AM   #6
Pl4yboy
Freeeeee Mason...
Pl4yboy's Avatar
Ron
They're in horrible shape. I think I have 3/4 of them but the last one is missing the center part that says 4x4. That is about the nicest looking one.
Ps... I have 6 lug wheels remember. Not 5. Those only fit 4/5 lug.
Old 01-22-2008, 06:14 AM   #7
68GMCCustom
then don't use the stand....use the standard center caps for the knock off stand... and drill the hole to mount the spinner on top?
Kurt -
Old 01-22-2008, 06:17 AM   #8
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
The one that doesn't have any logo in the center, i.e., has a hole, should be for the front hub of a 4X4 truck to stick thru.
Member Nr. 2770
Old 01-22-2008, 10:01 AM   #9
Pl4yboy
Freeeeee Mason...
Pl4yboy's Avatar
This is true... but it also means I have three caps for the rear and one front one =)
Old 01-22-2008, 12:51 PM   #10
72BLUZ
72BLUZ's Avatar
annies hub cap in chattanooga, tn could probably find you what you need. i have had great success with these people. phone: 423-855-4432
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 01-22-2008, 09:21 PM   #11
6-lug rallyes only came on 4wds.That`s why there are as many open caps as closed and they say 4x4 on them.Most guys find spinners and bolt them to the caps.I don`t think anyone makes a spinner center cap for 6-lug.
Old 01-22-2008, 10:41 PM   #12
63 & 64 Bowties
and a few others
I'm with Special-K, I don't think anyone makes one. I wish someone would.
The biggest problem, the clearance/tolerance between the hub and the hole in the wheel is almost "zero." So a cap that would slide in from the rear like a lot of custom aftermarket wheels wouldn't work unless it's paper-thin. Whatever you find will have to bolt on from the outside of the wheel just like the stock ones.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 01-23-2008, 05:23 AM   #13
weasel29gm
SLOW BUT SURE,BUT CLOSER
Wheel vendors at most swaps has 'em. Around $ 75-100 should do it.
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS.......
weasel29gm is offline   Reply With Quote
