Old 01-20-2008, 09:38 AM   #1
skokie
skokie's Avatar
Oil on starter bolts
I was gravity bleeding the brakes and while I was on the front passenger side i looked at my new mini start and I noticed that there was oil on the bolts. When I swapped my rear main seal I did put a new one piece oil pan gasket on but I could not tell where the oil came from. This engine has not been started in 2 months. I checked the front of the pan to see it it was blow back from when it was started and it looks clean. Has anyone seen this before?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 01-20-2008, 09:50 AM   #2
Re: Oil on starter bolts
Mine always had oil on the starter/starter bolts, but then none of mine (till this one, which has yet to be started) were new like yours.
Possibly small leak from back of the intake or valve cover.
Leak around the fuel pump mounting, or oil filter?
Just wild a-- guesses though.
Old 01-20-2008, 12:19 PM   #3
skokie
skokie's Avatar
Im going to get under there tomorrow and clean up the oil pan, around the oil filter, fuel pump, and flexplate. After that I should see where the oil is coming from.
68 build thread
Old 01-20-2008, 11:33 PM   #4
c10addict
c10addict's Avatar
Got the same thing on my Nova... Cant figure it out.... Its so minor though I havent really spent too much effort trying to figure it out... I will be curious to see what you find....
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 01-21-2008, 12:03 AM   #5
dave2953
Dave's not here, man
dave2953's Avatar
When the rear of my intake was leaking I always had oil on the starter bolts. You could check that. Not sure what else could be the culprit.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 01-21-2008, 12:52 AM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
I agree, take a look at the intake or head rear area, then if that is dry the rear seal is dripping on engine shutdown and then getting a flipping action on starter crankover.
Old 01-21-2008, 02:22 AM   #7
kenm78
Broken Down
kenm78's Avatar
Don't overlook the dreaded valve cover gasket as well!
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 01-22-2008, 02:14 AM   #8
PumiceMan
Junior Member
PumiceMan's Avatar
I agree - check the valve cover. My '68 camaro was dribbling a little oil from the starter area as well. I was afraid it was a pan gasket or rear main, but I eventually found that the rear corner of the pass side valve cover was leaking. Oil would run down the block and collect on the bottom of the starter, then drip on the floor. Turns out the cork gasket had pulled away from the corner of the cover just enough to let the oil by. New gasket did the trick.
69 GMC Sierra 1500 Custom
68 Camaro SS
18 GMC Sierra SLT
Living the dream
PumiceMan is offline   Reply With Quote
