01-18-2008, 11:06 AM | #1 |
seat belt restoration
I want to have my seat belts restored. My interior is saddle. That ssnake- oyl company says they can make my black belts saddle color. Has anyone changed color on belts? Am I better off to try to scrounge up some saddle belts? A complete set of 3 may be hard to find.
01-18-2008, 11:29 AM | #2 |
J'ville Junkman
Re: seat belt restoration
I'm cheap, so I say you could pop the plastic covers off the belts, bleach them and then dye them. You can do all this in the washing machine, just put each one in a pillow case and tie the pillow case up prior to washing in the bleach solution and subsequent dye. It may take more than one cycle. You can even use an old crappy belt for a test.
72 3/4t Suburban 402BB (Daily driver for 8 years) 68 GTO (never ending proj) 91 Kawasaki ZX-7R 57 Chevy 210 Wagon - 9 Passenger (Wife's project-working on floorpans) 73 Corvette (17 yr old daughter's: Another project - what's wrong with me?) 53 Willys M38 |
01-18-2008, 11:37 AM | #3 |
its all about the +6 inches
I'd just dye them black again, and color key them with black carpetting.
I would never bleach seat belts. Bleach weakens fabric. |
01-18-2008, 12:07 PM | #4 |
I couldn't agree more. Seat belts shouldn't be bleached. I wonder if rit dye will restore my faded black belts.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
01-18-2008, 12:09 PM | #5 |
I had some blue ones in the old GMC I used to have that i died, they stayed pretty decent lookin for 2 or 3 years of daily driver use (I wear them every time i drive).
01-18-2008, 12:48 PM | #6 |
Born Psycho
i've died black belts before with good sucess. never tried other colors but see no reason why it won't work.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
01-19-2008, 04:25 AM | #7 |
The guy who does the ones for Snakeoyl does nice work. I have seen his belts at charlotte and they look correct when he is through. I did not, however, use him but instead had my lap belts redone by Gary Terry CS-m.com. He does a geat job and should have any color that you want.
01-19-2008, 12:26 PM | #8 |
BlahBlahBlah
Check out this thread by John Fabris, he had his done by them.
http://67-72chevytrucks.com/vboard/s...d.php?t=180859 |
01-22-2008, 03:43 AM | #9 |
WORTHLESS CRUISERS
I had mine restored by Snake-Oyl. They completely rechromed, painted, new fabric, everything!! They made them look new. I also changed the color of the belt to match my seats. Sent them a sample and they matched it perfect. They arent cheap but you get what you pay for.
Scott Hammond Lancaster, SC 1969 Chevy2005 Chevy Silverado Z71 72 Chevy 1972 SWB 454 If you don't live for something, then you'll die for nothing. www.xclusive-images.com |
