Old 01-22-2008, 04:23 AM   #1
crm318
Alright Alright Alright
crm318's Avatar
causes of bad MPG
my truck has never gotten hybrid milage, but lately, my truck has been getting worse and worse milae by the week. what are some things to look for on the engine that would be causing this?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 01-22-2008, 04:36 AM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: causes of bad MPG
When was the last time you did a tune up? Clogged air filter? Vacuum leak?
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 01-22-2008, 04:38 AM   #3
ChevyC102007
ChevyC102007's Avatar
Ive been having the same problem as well, I know were part of its at I have a bad choke thermostat and I believe my carb is out of adjustment (again ) those would be two things Id check first. Also if the misture isnt getting ignited fully that will cause bad mpg IMHO. But someone else on here would have a better idea Im sure. Just my .02 cents
"When you were born, you cried and the world rejoiced.
Live your life so that when you die, the world cries and you rejoice."
[Cherokee saying]
2001 Dodge Ram Sport 1500 4x4. (old ride)
1987 GMC V1500 Sierra Classic ("new" ride)
ChevyC102007 is offline   Reply With Quote
Old 01-22-2008, 04:39 AM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
.... or maybe it's the E10 winterblend fuel?
My silverado has dropped about 1 to 2 mpg as well.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-22-2008, 05:23 AM   #5
Check your ignition.I know mine gets worse mileage with a key in the ignition.Seriously,how does it look under the hood?Smell fumey or see excess gas?Is it running smooth?The air filter and good spark with proper timing is the best you can do.
Old 01-22-2008, 05:29 AM   #6
cdowns
cdowns's Avatar
under inflated tires bad alignment worn suspension components oversized tires poor choices of manifolds and camhafts as well as a bad right foot can and will cause milage issues
Old 01-22-2008, 05:30 AM   #7
wibilly
wibilly's Avatar
check your tire presure, especialy if you have aluminum rims. they seem to lose presure as temps drop
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 01-22-2008, 06:19 AM   #8
WorkinLonghorn
WorkinLonghorn's Avatar
Mine started getting crappy mileage and I checked the vacuum advance by sucking on the line to it and discovered ther diaphram was broken.Then when I looked in the distrib I found that the centrifical weights were all stuck too.
I replaced the whole distrib with a new HEI type and it runs great but and am SURE the mileage prob.is fixed.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 01-22-2008, 06:49 AM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I know you are in texas, and the weather isn't as much an issue as it is up here... but you'd be amazed at how much it kills the MPG to idle the engine for 20 min in the morning to warm it up.
Assuming that isn't the problem... check the basics as mentioned already. Tire pressure, plugs wires, cap and rotor... how old are they? If you have points, then inspect them (or say screw it and convert it to HEI) Look at the air filter, clean the carb, yadda yadda yadda.
If you are like me and are too lazy to pull the 2500 pounds of junk in the bed... that'll hurt your MPG too. I have a whole front cross member in mine, frim rotor to rotor, plus a set of cement steps that we tore apart off the back portch... puttin a good squat on the 'ole girl. I KNOW it ain't helping my situation... but, I have no place to dump it.
You don't need some concrete chunks do you?
Old 01-22-2008, 07:02 AM   #10
Snow traction.
Old 01-22-2008, 07:18 AM   #11
C. M. Wolf
C. M. Wolf's Avatar
So far the above posts cover most causes that I would know of. The alcohol in the fuel mix can be a real culprit forcing you to have to run hotter ignitions and even a preheat strip on the fuel line before the carb. Alcohol runs cooler, cleaner, but cooler. It's also a very strong detergent so you need to check your fuel filters more often or run a second inline fuel filter,(which still has to be checked more often).
350 engines are nutoriously known for not 'breathing well', when you replace your air filter, put the tallest you can in.
The size and type of tires you run have a lot to do with gas mileage also. The narrower the tires footprint on the pavement is the less resistance the truck has to move. The taller the tire is the less the engine turns per complete rotation of the tire. Which means the truck travels further per engine rotation allowing better milaeage, at least to a certain point. This can be taken to far and begin to defeat the mileage per horse power on the engine. (Running vehicles that look more like a kid's "HotWheels Toy Car" or Toy-Monster-Truck" may look good, but it sucks... no really, it sucks gas to the point that the sound of the whirlpool coming from your fueltank can be deafening!)
I'm running a holley/700 carb,(which I need to re-jet), on an eddy-0/50-AL intake, the holley has an electric choke that sucks and I'm told the best cure for the alcohol-fuel/mileage thing is to run an "Air-preheat-plate" under the carb. (Since I have headers, I don't want to bolt on any air-preheat tubes up to the air cleaner can, which would need to be regulated also to avoid vacume-lock) *sigh*
It might not be a good thing for the board's bandwidth to get me started on the pro's & con's of running alcohol fuels in V8's. (Let's just ignore the fact that alcohol is cheaper, cleaner-burning, and can be made from the grass-clippings from your yard using a "Warren Still", and the BATF has deregulated the mfg'er of alcohol fuels up to 10,000 gals per year of personal use without a license.... since the "Carter Administration"!)
Michael
C. M. Wolf is offline   Reply With Quote
Old 01-22-2008, 08:19 AM   #12
crazy longhorn
Fabricate till you "puke"
Top of the line"lead foot".....yup Im guilty of that
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-22-2008, 09:45 AM   #13
crm318
crm318's Avatar
well since i have the day off tomorrow, i will go over all of the points mentioned. all of my specs are mentioned below. the HEI is also a new.
1972 Cheyenne
Old 01-22-2008, 10:03 AM   #14
BurnoutNova
BurnoutNova's Avatar
also keep in mind as the outside temperature gets colder, your fuel economy will go down. combine 20 deg weather with E10 and you can drop 3-4 mpg.
BurnoutNova is offline   Reply With Quote
Old 01-22-2008, 10:06 AM   #15
truckdude239
truckdude239's Avatar
gsa mileage whats that?
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 01-22-2008, 10:50 AM   #16
tim21391
tim21391's Avatar
i didn't know these trucks got good gas mileage....you dont drive it to save gas you drive it to have fun.....ok im sorry man...i had a problem with my trucks gas problem....as they said above.....check air filter..spark plugs..spark plug wires..points and rotor and cap on the distributor....check tires...see if you have a leak or what not....also my truck was gettin bad gas mileage...check to see if your hittin on all cylinders i was missin on 1 and 4 clyinders so i got my valves adjusted and that fixed my problem....how to check to see if your firing on all cylinders you take the air filter off so you can get to the distributor...pull each plug wire off the cap...each one when you pull it off should make the engine make a different noise....and you should see the spark jumping from the plug wire to the cap...if you dont have spark you have a bad plug or wire....that could cause a bad gas mileage problem...but yeah pull each one off if it doesnt change the pitch of the engine then you are missin on a cylinder and you need to get your valves adjusted
tim21391 is offline   Reply With Quote
Old 01-22-2008, 10:54 AM   #17
Sweet72
Sweet72's Avatar
I really like your "shoot from the hip" responses cdowns I really hate it when my "bad right foot" asses up good mileage!
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 01-23-2008, 05:13 AM   #18
mnunn454
mnunn454's Avatar
Mentioned above, but my 2 cents is with stuck choke, a vacuum leak or an ignition/timing problem.
BTW, the brakes aren't dragging on any corner, are they?
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 01-23-2008, 06:46 AM   #19
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
X2
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 01-23-2008, 07:10 AM   #20
crm318
crm318's Avatar
the truck rides smooth and doesnt pull to the side. checking the tires wouldnt hurt.
1972 Cheyenne
Old 01-23-2008, 07:38 AM   #21
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
Its 'possible" that the coil is dying. What do the plugs look like? If they do not look clean that might be a problem.
Frank
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
