Re: rocker+22's=?
After getting the stance in front, I finished the z in front of the frame. In order allow more room for the rack, I replaced the crossmember just in front of the engine crossmember with a piece of 2x4 tube. I also reinforced the z in front, and straightend a previously bent passenger rail.
Trey Oney |
Re: rocker+22's=?
I test fitted the motor and tranny and built a new tranny crossmember. The tranny is a 6 speed from and LT1 camaro.
Trey Oney |
Re: rocker+22's=?
At this point I still needed to setup the rack & pinion, but moved on to the back in order to get a "rolling" chassis. The first thing I did was to remove all of the old crossmembers and brackets. I then put in a piece of 2x4 tube across the back of the frame and built my own notches also out of 2x4 tube. Once I installed the notches, I boxed in most of the rear frame rails.
Trey Oney Last edited by bagged01extcab; 01-22-2008 at 11:25 AM. |
Re: rocker+22's=?
Before I reached this point, I decided to order a KP Components rear 6 link and a watts link. I could have fabbed this, but Why? KP has an extremely well designed and well built product. To be honest, If I would have known about the pb crossmember, I would have also went that route on the front. I also ordered a summit racing cell and built a platform for it in the rear frame rails.
*EDIT* I also welded up most of the holes in the frame before painting! ![]() ![]() ![]() ![]() ![]()
Trey Oney Last edited by bagged01extcab; 01-22-2008 at 11:33 AM. |
Re: rocker+22's=?
I went ahead and painted the rear, as you have noticed in the above pic. I still need a little longer dog bone for the canti, so that the shocks will fit. You should also be able to see in the above pic, where I built the crossmember in front of the rear end. I still have to gather the parts for the rear disk conversion (thanks glock35!) and am going to put an lsd in the 3.73 12 bolt.
After going back to the front, I realized there was not enough room between the stock control arms and the harmonic balancer. I ended up buying a set of strong arms. This gives me an extra 1 1/4". IF that's not enough room, I will have to buy a 6" balancer. Also. switching control arms caused me to be about 9/16" from laying in the front. I have parts to make upper cups. I believe I can use upper cups and do a little trimming on the spring pockets and get what is needed to lay again. In the meanwhile, I welded up everything on the passenger fender and got it in primer. I also stripped all of the paint off of the cab, both front doors and both fenders and primed. Here's some pics of how it sits now! I haven't touched the truck since the 1st of dec, but I hope to be able to work on it again soon. I've just been waiting on it to warm up a little. ![]() ![]() ![]()
Trey Oney |
chevy only
![]() Join Date: Sep 2006
Re: rocker+22's=?
nice work and man you have done a ton of it ! looks killer
CHEVY ONLY... Nothin Else ! |
Re: rocker+22's=?
Thanks! That means alot coming from somebody with the quality & quanity of vehicles that you have! It toke lots of planning and measuring, and lots of late nights. I done all of this in 2 months. I worked on it everyday after work, and all weekend, every weekend!
Trey Oney |
![]() Join Date: Mar 2005
Re: rocker+22's=?
Love it! From the pictures and the verbage, it sounds like you've got alot of energy and the skills to match. Can't wait to see more pictures.
