01-21-2008, 02:42 PM | #1 |
BlahBlahBlah
Looking for hubcaps, k20
I mangled up a perfectly nice pair of hubcaps today. I was trying to cut the center out to use on the front of my 71 k20. I have another pair I can try to mangle less, but I would really love to have a pair of factory fronts if anyone runs across some. The later model ones with the yellow bowtie are fine.
01-21-2008, 02:54 PM | #2 |
Re: Looking for hubcaps, k20
Did you try to drill them or cut them? I need a set as well and was considering drilling some out. Mike
01-21-2008, 03:15 PM | #3 |
BlahBlahBlah
I cut them. with a little bit of lip left over. I went to Lowes and found a plumbing pipe cap that was big enough to just slide over the front hubs. I positioned that behind the cap after I had cut it and tried pounding the cut edge down around the pipe edge to make my cut smooth. Is this making sense? LOL. Anyway it didnt work out like I had hoped. I ended up using a tin snips that didnt want to cut properly and sort of hacked up the edge instead.
Im pretty sure I can do it right on the next shot. Too bad it took me a couple of nice caps to figure it out. I would rather have a couple of factory cut caps though. If none turn up Ill cut up another pair. Im sure with much better results =) Last edited by CG; 01-21-2008 at 03:15 PM. |
01-21-2008, 05:32 PM | #4 |
I think I still have the front caps from a 72K10,will those work on your K20?
01-21-2008, 10:54 PM | #5 |
I have a set (4) of full size wheel covers for a 4x4 if interested. I can get pics on Monday. $25 plus the ride.
Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon Last edited by ScottH; 01-21-2008 at 10:54 PM. |
01-22-2008, 03:10 AM | #6 |
BlahBlahBlah
These caps have to fit the 8 lug wheels. ScottH I forgot to mention these are the dog dish style caps. westcoastflatbedder your caps are probably for 6 lug wheels and Im pretty sure they wont work. I will check into it today though and let you know.
Thanks guys |
01-22-2008, 04:05 AM | #7 |
Roadtrip!
Westcoastflatbedder, Sent pm on your caps if cg can't use them..
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
01-22-2008, 06:10 AM | #8 |
They can be cut pretty clean wil a hole saw for a drill
01-23-2008, 08:03 AM | #9 |
BlahBlahBlah
TTT...need to be 3/4 (8 lug) 4x4 ton dog dish caps. Thanks so far guys.
