1/2 ton with 1 ton srpings and shocks
On a 2wd truck, can you put springs and shocks from a 1 ton on a 1/2 ton? Are the springs the same length just different strengths?
thanks
79 GMC Sierra 5.9 cummins, nv4500 |
Addicted to Chevy
Re: 1/2 ton with 1 ton srpings and shocks
i am definite about the springs, not sure on the shocks, but i dont see why not. I have done the springs before - BEWARE its a stiff ride
Ru speaking of fronts or rears.
-Lincoln 1987 GMC S15 (soon to be a chevy clone) ![]() 2.5l, 4 speed, no ps, no pb, no ac Silence is golden, but duct tape is silver. ![]() Spoken by Cletus the hillbilly I like stickers... a whole bunch. |
The center bolts will be a different size so you will have to either drill out the rear axle holes, or grind the head of the center bolt down to fit.
sorry i was talking on the front. need something that can take the weight of the cummins a little better
1 ton coils shouldn't be all that harsh with a Cummins 6BT on top of them. I also recommend Monroe Gas Magnum shocks.
Insert Witty Text Here
There is also a heavy duty front spring option for half tons. I used to have them on my '86. Most of the auto parts stores carry them for about $80-$90 per pair.
Slonaker |
Addicted to Chevy
I would also reccommend the Monroe shocks. All the old techs around my town love them.
For the fronts look for a set of coils for a 1/2 ton with a 454 or any other big block and you should have what you want easily.
my truck was originally a diesel so it should already have heavier springs in the front. Im not sure what they are the equivalent of but i assume 1 ton would still be stiffer. So they will fit?
