Old 01-23-2008, 03:57 AM   #1
racerman85
racerman85's Avatar
Question Help on installing a fuel neck grommet please
hey guys, im getting frustrated now. With my problems with my front brakes-can be viewed here- http://67-72chevytrucks.com/vboard/s...d.php?t=273349 Now i've run into more problems... I cant seem to get my fuel neck grommet on my 67'. I have one that says its for a 67' but it wont go in at all. i tried WD40 but that is doing nothing... help please?
racerman85 is offline   Reply With Quote
Old 01-23-2008, 04:09 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Help on installing a fuel neck grommet please
I've always had the tank out when I put mine in then slid the tank neck into the installed grommet. Never had any problem doing it that way. Maybe they won't go in with the tank in place, not sure on that. Hopefully someone will chime in with some tips if they have installed one with the tank in place....
LockDoc
Leon
Old 01-23-2008, 04:28 AM   #3
Yeller68
Active Member
Yeller68's Avatar
I didn't remove my tank, but loosened it at all the mounting points. Then I put white lithium grease on everthing. It wasn't easy, but I got it on.
Yeller68 is offline   Reply With Quote
Old 01-23-2008, 06:35 AM   #4
GBWatts
GBWatts's Avatar
Put it in a pan of boiling water for a few minutes, carry the pan right out to the truck and as soon as you pull it out of the water slip it on. You will need a good pair of gloves to insulate your hands, but it should go on with a little pushing. I just put a new one on a couple months ago and this is how I did it!
GBWatts
68 C10 Stepside LWB
Howell, MI
GBWatts is offline   Reply With Quote
Old 01-23-2008, 09:29 AM   #5
71 super
71 super's Avatar
GB Watts' idea is a good one will have to remember it. I had trouble with mine, so I put in tank lubed the rubber and the cab with dish soap inside and outside and put the grommett on the tank and used a windshield stick to push the gasket on/around the filler hole. Take your time and this will work.
71 super is offline   Reply With Quote
Old 01-23-2008, 10:06 AM   #6
tim21391
tim21391's Avatar
id say put it in boiling water like the guy said....spray soap or any other lube n the place your putting it and then just do what he said....i did that to mine even in hot climate..and it went on piece of cake
tim21391 is offline   Reply With Quote
Old 01-24-2008, 01:53 PM   #7
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
It is easiest with the tank out, but not impossible with it in. KY Jelly works well because it does not have chemicals or petroleum contents that can damage the paint. I use paint sticks to push the seal around the neck. If they slip, they won't do the damage of a screwdriver.
PICKMUP is offline   Reply With Quote
Old 01-24-2008, 02:20 PM   #8
Longhorn321
Size Matters
Longhorn321's Avatar
I have never tried this on a fuel filler neck but it works well on other rubber parts that can otherwise be difficult.....GOJO! Cool thing is it washes right off.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
