Relocation Fuel Tank
I purchased a fuel tank relocation from Automotive Parts Network. I got the tank to fit it is all looking good until I messured the fill hole and it mesures
1 1/4" O.D. then I went to the local parts store and they are unable to order that size. Then the filler neck that I ordered is 1 3/4" O.D. It is my own stupidity that I did not ask what size is the filler hole before I ordered it, but I thought it was all the same size, so now I am not sure what to do. Has anyone have any ideas or had this same problem. Any help would be greatly appreciated. |
Car Knocker
Re: Relocation Fuel Tank
What I did is bought a piece of 1 1/4" fuel hose a my local parts store and then took my filler neck to the local muffler store and had them weld a reducer on the the neck.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
