Nothing to see here.....
![]() Join Date: Jun 2007
WTB - 2" Rear Lowering Blocks and U-Bolts for Coil Axle
looking for a 2" lowering block and u-bolt set up for a coil spring rear end that someone is not utilizing.
Thanks!!!
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
The Older Generation
Re: WTB - 2" Rear Lowering Blocks and U-Bolts for Coil Axle
Doug,
If you can't come up with any you might try these folks. They are in Olathe, KS http://www.generalspringkc.com/index...parent=32&pg=1 They should have what you want. (just type "blocks" into the search box and scroll down) I just cut a couple of pieces of 2"x2"-1/4" wall tubing for mine, then had the spring company bend up new "U" bolts 2" longer... Worked great. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-25-2008 at 03:03 PM. |
#3 | |
Bloo
i think i have a set of blocks, ill check tomarow and let you know. i dont think i have the u-bolts to go with them though
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
1997 GMC Sierra Ext 1965 Mustang |
#5 | |
pm me if you still have the blocks only. 70GMCer, I saw those blocks. Looks like he just made them out of .50" rect stock. That may be an option!!
Made mine out of some 2x6 tubing and work great.
These boys have the u bolts http://www.stengelbros.com/U-boltKits.htm |
Bloo
heres the pics, they are 3" though. they could extremely easily be cut down. i managed to find one of the u-bolts, but after finding it i didnt bother finding the other... those suckers are thin! i ran these blocks in the rear of my k20 as lift blocks, but they were listed as lift/lowering blocks. they are the tapered kind to fix your pinion angle
#8 | |
